Polycom SoundStation2 Audio Conference Logo
Posted on Oct 23, 2009
How do I connect 3 phone calls on a Polycom Soundstation 2. There doesnt seem to be a hold button
A
Anonymous
It depends on what system it is installed on.
NUT, generally, with the first caller on, press flash you will get intercom tone again, dial 9 and connect to the next party. Once connected, press flash again and you should be connected to the original party.
1helpful
Polycom soundstation 2 does not have a dial tone
That Polycom runs off of Analog dial tone.
Either a dedicated line or in most cases from an ATA off the phone system.
You should be calling your vendor/tech in that handles the phone system to check programming, cabel, jack and the Polycom itself too.
We have an old model of the Polycom Soundstation. It doesn't have a screen. It has a hangup function, volume control, mute button, numbers 0-9 (of course) and a button called 'R' - do you know what this...
you cant answer numerous calls on this system - you will need to set up a dial in number on a phone bridge provider and have all participants call into that number and then all of you will be in same conference call. this is best quality and the most managable way to do this. i am sure your phone provider can help you set this up. R if i remember correctly is for redial
2helpful
Polycom soundstation 2w has no signal. tel line is good, power to transmitter is good. Soundstation seems ok, can get to menu & settings ok.
Hello Edward,
This is a known issue with this product that requires a software upgrade to resolve. Please download "SoundStation2W Software Upgrade" from the Product Support page of our website and follow the included instructions. If you need any assistance please don't hesitate to call for assistance at 1-888-248-4143 Options 2, 4.
Regards,
James
1helpful
How to reboot soundstation 2w polycom if you forgot the password
egistering Base Station on Polycom SoundStation 2W
Hold down 1,4 and 9 until green & red lights flash. Then hold down the page on the base station.
OR
You can register the base station to the console by:
1. press menu key
2. Select Admin Setup
3. Select Registration
4. You will see "Register with Base Station" in display. Press the Register softkey.
5. You will see "Power cycle base station then press ok". Unplug base and plug back in and press OK softkey.
6. You will see "Press and hold the paging button on the base for 10 seconds"
7. You will see Registering in the display on the console and then it should go to ready mode.
2helpful
Polycom Soundstation 2 disconnects during calls
this does not appear to be the sound station problem it appears u ve connected this system behind an epabx extension .if yes the extension is programmed for a call disconnection time of 15 mins.ask ur epabx programmer to change it to infinite
2helpful
2answers
Opening Up A PolyCom Soundstation EX
you have to remove the rubber footings directly under the keypad of your polycom. . . It has 2 screws under those rubber footings.
2helpful
3answers
Polycom soundstation 2W
I went to Admn Setup to reboot the system from Please Wait.... & it doesn't work!! Best Solution posted on Sep 19, 2008 2%20stars.png
noavatar_s.gif Guest
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
Just had this problem with the 'please wait' - go into the admin setup and select Reboot Phone - it then works!
VTX1000 Conference phone
thats very simple,simple when you press CNF dial the number when the call recieved press join & the number 3 for a two sec .you will be connected
Adding person to a teleconference group
How can I add 3 other people on the conference call using a Polycom Soundstation?
13helpful
5answers
Conference call with a Polycom SoundStation EX
The conferencing capability to bridge 2 (or more) external stations comes from the telephone equipment/service that you have purchased. Either you are behind a PABX or Electronic KSU, which provides multiple phone service to your office, or you purchase conferencing capability from your local telephone provider (Verizon, AT&T, etc). In either case, the way to initiate a conference call would be the same as when you would have a desktop/office phone and establish a conference/bridged call to external parties. Usually this occurs by having one party on the line, flashing the disconnect button momentarily, getting a new dial tone, dialing and connecting to a second party, then flashing the disconnect button again, which signals the equipment to bridge those two calls to your station.  On the SoundStation EX there is a Flash button that provides that capability of momentarily flashing the disconnect button.  Try and see if that works. If not, then you will need to make arrangements to purchase the external equipment or service from your provider.  If you have the PABX or electronic KSU, it may also be a configuration option that you will need to have your support person for your telephone system, activate for that station connected to the SoundStation EX. Hope that helps.
Top Polycom Lands Phones Experts
k24674
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
