Question about Janome 8080 Computerized Sewing Machine
Sewing leather what needles do I need to sew light weight leather such as hand bags and purses?
Posted by doc5270 on
Adwer Drahal
    New Friend:
    Problem Solver:
  • 12 Answers
Pure and genuine vintage leather satchel bag online
Leather Satchel
Posted on Nov 13, 2014
Anonymous
    New Friend:
Leather needles, they make little cuts in the leather as opposed to normal needles that try to punch wholes, which does not with such dense material as leather.
Posted on Oct 23, 2009
How can I find out if a White sewing machine model 599 will sew leather?
It depends on what you are sewing. If it's boots, shoes ,saddles, purses or heavy duty stuff like that I doubt it. But you could ask the manufacturer. On the other hand if you are sewing light weight skirts etc or using pleather, its not so much the machine but the needle which should be an 18 with heavy duty thread and a longer stitch.
Hope this helps .
Sep 02, 2018 | White Sewing Sewing Machines
Yamata gc8500 needle thread breaks as soon the machine goes fast
Make sure you're using the correct size needle for the fabric you're sewing.
Delicate / Very light weight.... china silk, fine lace, organza....size 8 or 9 .....Light weight taffeta, lining fabric, thin velvet, synthetic sheers size 9, 10 or 11.... Medium weight cotton nylon, crepe, knits, flannel, spandex, linen, poplin, wool, muslin size 12 or 14..... Heavy weight fleece denim, leather, vinyl upholstery fabric size 14 or 16....Very heavy weight ; heavy canvas ; thick leather size 16 or 18
Apr 28, 2018 | Yamata Sewing Machines
I have a Singer sewing machine#7258 what setting and needle and thread do I use to sew leather
Hope it is light weight leather. It should not be used on heavy leather.
Use a brand new heavy needle (leather). Avoid using upholstery or thicker thread as that sometimes does not feed well through the needle eye. Set it for a longer stitch. And you might want to adjust the presser foot pressure to accommodate the thicker fabric under the presser foot. Also, a leather foot, roller foot, or walking foot may be helpful--if if not available, try using parchment paper (or something similar) on the surface of the leather to help it slide under the presser foot..
Jan 06, 2018 | Singer Sewing Machines
Singer 99 not feeding heavy thread.
Unfortunately, your domestic machine was not made to sew leather. It can probably sew lighter weight leather with a lighter weight thread. Your thread is most likely too heavy for the machine you are using so it is not able to pick it up properly.
Apr 19, 2017 | Singer Sewing Machines
I want to know if the machine can sew thick patches or badges
Your gonna need a machine with a over locker on it.
Oct 30, 2016 | Sewing Machines
Have a Juki 8700 what type of needle do I need to sew leather? Also what kind of leather have a Juki 8700 what type of needle do I need to sew leather? Also what kind of leather foot do I need?foot do I...
hi there
regarding your inquiry about JUKI machine model DDL-8700 , first your machine type was what ? DDL-8700/SS ( for light to medium material , DDL-8700/HS ( for jeans and can use to sew light to medium lather, type of needle is DBx1, size for lather was 18 and you can use thread number #30 and #20. one more thing you want to change your presser foot to teflon presser foot ( please see attached photo for that presser foot you want to buy.
if need more information please ask
thanks and best regards
ASHRAF ABOZID
CAIRO - EGYPT
[email protected]
Mar 07, 2015 | Juki DDL-8700
Can you sew leather or vinyl on Husqvarna 415? If so, what tension, needle and foot should I use?
Ok. Depending on the thickness... garment weight leathers can be sewn with a domestic machine... Most often an even feed foot (the home version of a walking foot) is needed. You will likely need a larger leather needle and somewhat longer stitches than you would normally sew.
As for stitches looking messy on the back that is a top tension problem... you'll need to tighten the tension until that goes away. AFTER you have made sure you have your machine threaded correctly with the presser foot in the up position.
Aug 19, 2012 | Husqvarna Freesia 415
Sewing a patch...what type of needle do I use
Always pick the needle type and size according to the fabric that you are sewing. I'm assuming if you are "patching" you might be using an iron on patch product on the underside of the garment and you should try to use a similar weight to the garment's fabric weight to do this.
If you are patching denim for example, you'd use a "denim" needle (teflon blue coating to slide through the fibres better) if you can, probably size 90 or 100. If you don't have a denim needle then just a regular 90 or 100 needle will suffice.
If sewing knits, use a ballpoint needle. For leather and vinyl use a Leather needle, these have a different shaped tip to piece the leather.
Try this link for more good general info on needles http://sewing.about.com/od/sewingmachineindex/ig/Sewing-Machine-Needles/ you might want to print out the section on sewing machine needle sizes and pin up in your sewing room.
My sewing needle selection is over 25 different needle packs and I probably buy 4-6 packs a year to ensure I've got the right size on hand. Change your needle for every new project - a needle stays sharp for about 4-6 sewing hours then should be replaced. If you are hearing squeaking or popping noises, your needle is blunt, chuck it.
In the words of my sewing mentor Wendy "Dont spoil the ship for a ha'pworth of tar" .
Mar 07, 2011 | Brother LS-2125 Mechanical Sewing Machine
Question==>JUKI dnu 1541 or ddl 8300n
Might I be so bold as to disagree with Allmakes.
Why would a manufacturer build different models of industrial. They are designed for differnt jobs. The 8300 is a high speed garment machine, the 1541 is a compund feed upholstery machine. The motor is the same HP and does not affect the ability to sew heavy. The garment machine will sew garment weight leather just fine but you will have problems getting the fabric to feed properly particularly over seams. The other issure you may find with a garment machine is it's ability to handle heavier threads. I suggest that the 1541 would be a better choice for making bags and purses.
Jan 26, 2008 | Juki DNU-1541 Mechanical Sewing Machine
Janome 8080 Computerized Sewing Machine Logo
232 people viewed this question
Top Janome Sewing Machines Experts
tina gallow
Lee Hodgson
Lee Hodgson
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
