Question about Panasonic CQ-DF903U CD Player
My cd player in my car won't play cd's now. When
My cd player in my car won't play cd's now. When I put one in, it says E2. What does that mean?
Posted by cowhorns776 on
Michael Thomas
  • 3,053 Answers
Hello there:
this means that it cant read the cd rom , because of the following conditions the cd rom is scratched or dirty or that the lens on the player is dirty and is in need of cleaning or that the player has failed all together
ok so try to clean the player with compressed air and a cd cleaner with some cleaner on it first than make sure that the cd rom is cleaned and not scratched and if still nothing is working you might want to consider a new player ok? Hope that this is very helpfull
best regards michael
Posted on Oct 23, 2009
Which fuse is it to take out if the cd player reads unreadable disk for any cd I put in...2006 Hyundai sonata...
Kirk, I am not aware of any fuse to remove to make player work. Try cleaning the lazer/head. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
CD player doesn read disc
2007 Sonata Ltd CD player won read discs
How to Fix Car CD Player
May 19, 2016 | Hyundai Cars & Trucks
My stereo was working just fine, playing all of my cd's easily. Then all of a sudden one day, it won't play any of my cd's. I keep getting the E2 error everytime I put in a cd! a brand new cd.. E2. I know...
The laser beam at the tracking head may have been disrupted. That means the CD's are just fine, only the read head will not function. Unfortunately, the cost to repair is more than an replacement. Get a cheap $20-30 portable CD/DVD player at Walmart.
Feb 11, 2018 | Panasonic CQ-HR1003U CD Player
Ford focus 2002, radio working, cd player showing e2 problem & wil not working, can you please help?
According to the Ford Audio Manual ERROR E2 is "Over temperature error"....meaning that the unit is getting too hot.
Check the air vents and make sure your car heater is not leaking hot air into the CD unit
Aug 24, 2010 | Car Audio & Video
`Sony CD player won't play burned discs
Many of the older Car CD Players will not play CD-R's or they may with static sounds behind the music. What you need to do is try using a different brand of cd-r disc. If this doesn't work then it means that you may need to replace the CD player because the model that you have may not be decoded in order to play CD-R, CD-RW, play MP3's or anything of that such.
Get back to me if this doesn't work I'll help you square it away.
Nov 19, 2007 | Sony RCD-W10 2-Disc CD Recorder
Wont play cd
Is this a "home burnt" CD? The code means CD ERROR #2.It is usually because the CD was written in a format the head unit can not play.If it is a studio CD. I would contact Panasonic and find out what code # 2 means.I had a code too because of what I said before but I do not remeber the # it was.
Nov 11, 2007 | Panasonic CQ-DF903U CD Player
Panasonic CQ-DF903U CD Player Logo
608 people viewed this question
Top Panasonic Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Michael Thomas
Michael Thomas
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
