Question about Moen Plumbing
I have a 2 handle moen kitchen faucet that is leaking at the base, I do not know how to remove the spout cover..I have tried removing it by prying with a screwdriver but I did not want to force it. does it unscrew or what?
Posted by dmoreno32 on
Anonymous
    New Friend:
  • 119 Answers
The spout cover is threaded and unscrews then remove spout and replace the o rings with a Moen o ring kit only use Moen brand or Ace Hardware brand
Posted on Nov 23, 2009
5 Related Answers
Bruce Hathcock
  • 3600 Answers
SOURCE: I have a moen pull out kitchen faucet that leaks
You have a bad internal o-ring or the sprayer o-ring is leaking, if you look under the sink turn it off and then turn it back on, if you see it leaking out the center shft where the water pipes go into then the faucet may have a broken pipe or loose pipe. check and tell me where it's leaking at. You can buy kits to repiar them they are inexpensive.
Posted on Aug 30, 2009
Anonymous
  • 171 Answers
SOURCE: kitchen spout leaks
Hi buffy9,
I'm Harvet the Master Plumber.
Your question is: You have an American Standard two faucet in my kitchen and the base of the spout leaks at the base. How do you remove it and replace the washers?
Are we talking about an American Standard two HANDLE faucet or one of the single handle models?
Thank you,
Harvey your Master Plumber
Posted on Oct 17, 2008
1stBSP
Steven Foerst
  • 52 Answers
SOURCE: I have a Moen Single Handle kitchen faucet, it's
Replace the "O" rings that are behind the spout portion. You will have to remove the top of the faucet and pull up on the spout section. There will be a couple of "O" rings there. It is best to have Moen send the parts to you as locating the proper size "O" rings can be difficult.
Posted on Apr 06, 2010
Anonymous
  • 127 Answers
SOURCE: Moen kitchen faucet model 7430 leak
cartridge does not stop that type of leak. If it is leaking from around the base of the spout it is o-rings that are the problem that are onthe valve after you pull the spout all the way off.
Posted on Oct 18, 2009
Anonymous
  • 160 Answers
SOURCE: moen kitchen faucet spout
there should be a removable "button" on the faucet base below the handle. under there, there should be a set screw. loosen the screw, remove the handle. now u can adjust the base, collar, etc. to ur liking...don't forget to reassemble everything the same way u removed them.
Posted on Dec 13, 2009
Testimonial: "that was one reason I was looking for a diagram to show EXATLY how everything goes back !! will try your suggestion thanks"
How to remove leaking neck of old two handle kitchen faucet and fix
The cap at the top will either unscrew, or pry up with a small flat blade. Will be one or the other, haven't seen one of these in many years so I don't remember.. If its leaking around the spout at the base you will need to replace the O rings. Moen provides many repair kits for free. Go to H Depot and ask the plumbing guy to give you a repair kit for this model, it may be free, with instructions included!
Aug 11, 2014 | Moen 7900 Chateau Two-Handle Kitchen...
Leaking CA87681 moen kitchen faucet
Throw a cloth over the cover to prevent scratching the finish and grab it with a large pair of channel locks and unscrew it.
Nov 18, 2013 | Moen 7907 Chateau Two-Handle Kitchen...
7700 series Moen leaks at top and bottom of base hub
You can just replace the o-rings. You have to remove the large nut at the base of the spout. I posted a blog post -and a video about me replacing mine.
http://blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html
The replacement o-ring and retainer parts were free to me. Hope it helps you.
Aug 17, 2011 | Moen Monticello Single-Handle Kitchen...
Moen 7700 leaking at base of faucet. how do you get to o-rings
Here's a link to show you how to get the spout off using "strap wrenches" The allow you to get the nut off at the base of the faucet spout without harming the chrome finish.
There is also a video at the bottom of the blog post showing how I did it.
Oct 17, 2010 | Moen Monticello Single-Handle Kitchen...
I have a Moen Single Handle kitchen faucet, it's leaking at the base and below the neck (where is swivels for the faucet to move side to side). How do I fix it?
Mar 29, 2010 | Moen 7840 Camerist Single-Handle Kitchen...
Moen kitchen faucet spout
Dec 13, 2009 | Moen 7310 Legend Single-Handle Kitchen...
Oct 17, 2009 | Moen 87530 Touch Control Single Handle...
Plumbing Logo
2,436 people viewed this question
Top Moen Plumbing Experts
john h
Bruce Robin
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
