Question about Sony Playstation 3 (PS3) Console
My Ps3 makes a loud fan noise after 15-20 minutes
My Ps3 makes a loud fan noise after playing a game fo 15-20 minutes is there a solution but it never happens when i leave it on the XMB
Anonymous
    New Friend:
    Problem Solver:
  • 5 Answers
Its your backup fan turning on you must not have adequate venitlation take it out of small place and put it near a fan or window
Posted on Oct 22, 2009
Testimonial: "TX ALOT M8 I CAN NOW aply mw2 in piece ;-] "
PS3 fan keeps making noise
If it's an older system, break that thing open and clean it! ^^ If it a newer system, or you just don't feel like stripping it to clean it, then use an air compressor to blow the crud built up in the back of the system. Make sure the compressor hose is dry, as you don't want water to get inside your system. Good luck, and I hope this helps.
Jan 21, 2014 | Sony Playstation 3 (PS3) Console
PS3 WHEN CONSOLE SWITCHED ON IT BEEPS THEN TURNS OFF AND FLASHES RED
My guess is its going to die soon. I would back up most of your stuff on a hard drive if possible. If it gets that far. I had this happen to my 40GB PS3 about a year ago. It turned on for 5 minutes then off. Soon after that it didn't turn on. And it was making really loud fan noises.
What are the specs of your PS3 and was it making loud fan noises before? Consider buying a new PS3 slim?
A quick guess that i just thought is try doing the fan test before turning it on. Turn Off PS3 completely (switch in back) Hold eject button and Turn on switch.
NOTE: This is dangerous and can harm the PS3.
Good Luck
Nov 29, 2010 | Sony Playstation 3 (PS3) Console
Ps3 loud fan noise
Don't do anything your fan is just fine it's just running faster to keep it cool when you hear a clicking sound at high speed then you should be worried about it cause your fan is failing and should be replaced
May 31, 2010 | Sony Playstation 3 (PS3) Console
My Ps3 will start to make noise when i play?
well the noise is a loose nut or could just be the fans,and/or reading cds........but if it won't read some ps3 games......well idk
Apr 17, 2010 | Sony PlayStation® 3 (80GB) Console
Ps3 plays for a few minutes and just shuts off all by itself, and i think the fan is not making any noise
The ps3 could be overheating if the fan is not working, make sure the fan is clear of any obstructions and dust, the fan will need changing if it doesnt fire up.
Nov 03, 2009 | Sony Playstation 3 (PS3) Console
PS3 Loud Fan Noise
It sounds like it needs to be cleaned, just blow some compressed air into the fan area, unless you can actually get it opened, then that would be better.
Hope this helps!
Aug 25, 2009 | Sony Playstation 3 (PS3) Console
When i turn on my ps3 it works fine until i play for about 15 minutes then a loud fan starts running.
Does the PS3 still work while the fan is running. This is typical with PS3, especially if the fan is dirty. It comes on and off to cool down the processors.
Apr 20, 2009 | Sony Untold Legends: Dark Kingdom
Loud fan noise
i had the same problem once make sure that the ps3 is not on a carpet, or move it to a hard suface and a more ventilated area,, that is probably the best solution since the ps3 requires alot of cooling down.
Apr 03, 2009 | Sony Video Game Consoles & Games
PS3
It is your outake fans. most likely bearings or something is lodged close to one and doing the old popsicle stick in the spokes trick to you.
Aug 11, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
750 people viewed this question
Top Sony Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Marvin
Marvin
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
