SOURCE: canon pwershot s1 IS E18 error code
why dont you buy a new one and return this one in the poackage?
SOURCE: E18 error on Canon ixus40 - lens stuck
The E18 error is an error message on Canon digital cameras. The E18 error occurs when anything prevents the zoom lens from properly extending or retracting.[1]
The error has become notorious in the Canon user community as it can
completely disable the camera, requiring expensive repairs.
A quick internet search for "E18" + "canon" quickly reveals hundreds of similar complaints.
ConsumerAffairs.com reports that the "lens has a feature called
bellows claw, which is a gear that physically extends and retracts the
lens. A piece that holds the lens, the barrier plate, is not large
enough and can sometimes cause the bellows claw to malfunction,
resulting in a stuck lens". The result is a black screen that only
contains the error message, E18. Another problem mentioned on the site
blames a sticky iris in the lens, caused by grease entering inside from
the microphones built into the lens. The buildup freezes up the ability
of the lens to open.
SOURCE: message e18
There is some sand or other light material blocking the lens
Testimonial: "I actually got it to work by simply charging the battery and changing the memory card"
SOURCE: ERROR E18 Camera buzzes, then several beeps as
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need
any further assistance. Also, please be so kind to let me know if you
found this helpful.
Regards
Andrea
