Question about Honeywell 5804 Ademco Wireless Security watch
How can we use the Honeywell alarm LYNXR series without the service if we dont know the installer code. Where would the code be found anyway?Thanks
Posted by congamann2 on
Anonymous
    New Friend:
  • 10 Answers
You have get into programming by disconnecting the power then reapplying it (battery first) within30 seconds press1and 3 ( same time ) until you see 20 flashing. press #20 and the installer code will be displayed one number at a time. If you want to change it press *20and whatever 4 digit code you want the installer code to be. Next Press *99 The system will reset and come out of programming
Posted on Jan 21, 2010
Security code program for ademco alarm 6150
6150 is the type of keypad you have the alarm system itself. The 6150 works on a number of different Honeywell panels. You need to locate the main metal box and open it. There should be a white sticker on the board with the panel type. (Ex. v10,v20, Vista...)
Oct 21, 2011 | Honeywell 5804 Ademco Wireless Security...
I have an Ademco 4110XM -CN universal controller that I purchased back in 1993. The system has performed just great up to a few days ago. I get an trouble code #91 which I can't find reference to in any...
I have found the User Manual, Installation Manual, and the Programming Form at the following website:
http://www.diyalarmforum.com/board/index.php?topic=95.0
However, this is a restricted website and you must register to download these manuals and forms. And, the Admin. must approve the request before you can download them.
You can view the Installation Instruction Manual here without registration:
http://www.info-techs.com/ademco/files/controls/installation/4110xmii.pdf
Additional programming information can be viewed here:
http://forum.doityourself.com/archive/index.php/t-175366.html
Contact ID Format Guide:
http://www.walkerhomesecurity.com/home_alarm_manuals/ademco/a4130xm.pdf
I haven't been able to reference the # 91 code unless I just overlooked it.
Jan 31, 2011 | Honeywell 5804 Ademco Wireless Security...
I disconnected the ademco from the wall to paint. not sure which slots to put the hot wire and ground in from the transformer. have a LYNXR-1 model
The AC power wires for a Lynx (actually, almost any alarm panel) are from a transformer--there is no "hot and ground". It doesn't matter which wire you put to which terminal, as long as you connect them to the AC connections.
Aug 29, 2010 | Honeywell 5804 Ademco Wireless Security...
I need to turn off the alarm. I hit func/stay by mistake
without knowing the system type I can only guess. try entering 4 digit code then 1. if you don't know the code and have never really used system try 1234 then 1. this is assuming you have an ademco panel.
Apr 27, 2010 | Honeywell 5804 Ademco Wireless Security...
Setting alarm to beep when doors are opened.
If it is a honeywell product enter your code then 9
Jan 12, 2010 | Honeywell 5804 Ademco Wireless Security...
Honeywell Ademco 128B alarm panel
You could use a vista-key module on the polling loop without using a card reader. My question is, what will hold the door shut if the strike plate is unlocked? It sounds unclear what the client wants their system to do and or what type of system they want
Nov 08, 2009 | Honeywell 5804 Ademco Wireless Security...
I have a security system lynxr-1 i want to use it with out servive i have a 103 fault i cant get out of
Log in if you know the installer code and go to field 43 by pressing *43 and press #. Then press *41 and press #, then *99.
Sep 06, 2009 | Honeywell 5804 Ademco Wireless Security...
Need to know which pole is positive and which is negative for honeywell transformer for alarm system (120VAC 60 HZ .30 AMPS)
If it is a VISTA or a LYNX then it doesn't matter as the transformer puts out AC current instead of DC. This is done so you can have very long wire runs of very thin wire without causing problems.
Think of your house power, it comes from the high tension lines over many dozens of miles and they power entire city sections (AC-Power). But if you're on DC (when the poles matter) such as in a car, you'll then need a HUGE wire just to run a subwoofer amplifier by itself. Yet power tools can run on a 50' extension cord that's 1/4 the thickness and be fine! the AC power delivery is much more efficient in that respect, and alarm systems usually have wire runs that span the whole house and they're usually all around 18 to 22 guage wire (very thin) to save on installation costs...
Jun 23, 2009 | Honeywell 5804 Ademco Wireless Security...
Honeywell 5804 Ademco Wireless Security watch Logo
897 people viewed this question
Top Honeywell Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a Honeywell Watch Expert? Answer questions, earn points and help others
