Hello
Can I replace by myself, one of the two disk drives installed in my Lacie 2Big triple? I would like to use a non-LaCie disk as replacement part
The storage space is set on RAID 1, so the laCie should rebuilt the 2nd new drive by copying the old dik, isn't it?
Thanks for your help
SOURCE: deference Lacie d2 Quadra1TB/Lacie big disk ?
It's all about the interfaces.
The Quadra has four interfaces:
• eSATA
• FW 400
• FW 800
• USB 2.0
The triple has all but the eSATA interface listed above.
For doing video work you want a big drive with a fast interface. If you have eSATA available then that's the fastest. If you don't then you're just as well off to go with the triple interface. The FW 800 would be the next fastest, then the USB 2.0, then the FW 400.
Because of the way that data is transferred I believe that when doing video work you would be best served by the FW 400 instead of the USB 2.0 even though the USB is faster I don't believe it is a full duplex communication so the FW 400 is actually better for video.
SOURCE: Hi guys, accidentally pressed the big blue button
Sounds like you may have been unlucky in starting the reformatting software for the drive. Goto the following link to check out the documentation for the product:
http://www.lacie.com/download/manual/2big_Quadra_en.pdf
SOURCE: I have a 1TB LaCie 2Big Quadra. It has 2 500GB
I have the same problem too on my 2big form lacie . If I use 2x 1,5 tera disk in "fast mode" or in "big mode" my disk manager only shows 746 gigs available (it should be at least 2,5 terra).
If I use "safe mode" so my system can see 1,3 tera available, wich is normal for a raid mirror configuration.
I hope to find a solution quickly.
SOURCE: My Lacie Hard Drive only
Please explain what you mean? When you plug in the drive it recognizes the drive but the size is showing to be extremely small?
Please let me know so I can help further.
Thanks!
EJ
