How do i put my printer online, as at the moment it says it is offline.. how so i do it?
The printer needs to be powered on and the "Ready" light on. At that point, the printer reports to the host that it is online sand ready.
Don
SOURCE: printer is offline
If you open your "printer's and faxes" folder you can right click on the printer and select "use printer online". Another thing that you want to do is make sure that the printer is ready and no alarm lights or messages are showing.
I hope you find this information helpful.
SOURCE: printer is offline and won't go online
Let's try to isolate the problem. First lets check if your windows was able to detect your printer. Go to Control Panel then go to System. In the System Window go to Hardware tab then click on Device Manager button. On the Device Manager Window you will see the list of devices on your system. Look for Universal Bus Controllers and expand it bu clicking the + sign. Check if your printer is listed. If you printer is listed then your Windows was able to detect the printer and the problem is on your printer or printer driver. If this is the case I suggest you update the driver by going to manufacturer website and download the latest SW.
SOURCE: my printer is offline. how do i get online
Check the USB cable, make sure it is working. or restart your PC
Hope this helps you.
Please If this solutions solves you problem, please do not forget to rate my solution. If not, then please comment back so I can help some more
SOURCE: 1720dn Laser Printer: printer offline. unable to set online....
I Open my browser....I signed in to my router as administrator ....
Mine is 192.168.1.1 ....
I went to status in my router ....
Then to local network ....
Then to DHCP Clients Table ....
This is how I found what printer address the was.... Then I typed the printer ip address into my browser
Mine happened to be 192.168.1.105 ....
Yours will probably be different....That got me to the 1720dn printer menu ....I clicked on Configuration ....
I clicked on Print Server Settings
I clicked on TCP/IP
I clicked on Set static IP address.
I changed IP address from 192.168.1.105 To 192.168.1.125
and Submit....Now you can get to the printer menu at 192.168.1.125
Go to run....
Printers & Faxes
Right click on Dell laser printer 1720dn
Properties. Ports ....
Add port ....
Double click on Dell Enhanced TCP/IP ....
I named the port My dell laser 1720 dn....Where it said enter a single IP address or host name I entered the new address 192.168.1.125
the clicked OK ....
Properties....Ports
Choose your new port ....
Start-->printers and faxes-->right click on the printer-->properties-->make sure it's set to print online.
or
Printer Spool offline: If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year! Thanks, Joe
Disconnect the USB cable, go to RUN and type in services.msc and then find print spool and right click, then choose restart.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
