LE stands for locked motor error. The first thing you should try is simply unplugging the machine for 10 minutes. If the problem continues the next most likely cause is the hall sensor. To get to the hall sensor remove the back cover, then remove the wheel that is attched to the drum. Undre that wheel if the stator (motor). At the bottom there is a sensor that spans about three of the windings. This is the hall sensor. It is not very expensive. If neither of those work you will need to replace the Stator (motor)
