I have forgotten my 3220's security code..i have put security code.I brought new Vodaphone sim and trying to access from this handset.It is asking for Security code. even i have forgotten the memory option..phone or sim ...plz help me
hi,
The master code is a 10 digit number that will always be accepted as if it were your actual security code.
You can use the master code to change your security code back to what ever you like. When your Nokia handset asks you for the security code simply enter the master code.
1-Turn on the phone without sim card .
2-Pull off the battery cover and insert any non-accepted sim card (without turning off the handset)
3-Do full reset *2767*3855# , phone will reboot and goes to Menu .
4-Customize Sp-lock code *7465625*638*00000000*00000000#
5-Unlock your phone with new SP code #7465625*638*00000000#
6-Enjoy G600 unlocked
SIM pin code: This is a pin code that locks the sim card until you enter the correct code. This protects your account, even if your sim is put into another handset. To reset it, you need the PUK code: Pin Unlock Code (PUK) If you miss key (or forget) your SIM pin code, and enter the wrong one 3-5 times in a row, the SIM will lock up, and you’ll need to enter the PUK unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don’t try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled. Phone Security Code: The default security code for Nokia is 12345 This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code code: Master Reset Code
Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security Code wrongly too many times. Which is the one that you want?
SIM pin code: This is a pin code that locks the sim card until you enter the correct code. This protects your account, even if your sim is put into another handset. To reset it, you need the PUK code: Pin Unlock Code (PUK) If you miss key (or forget) your SIM pin code, and enter the wrong one 3-5 times in a row, the SIM will lock up, and you’ll need to enter the PUK unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don’t try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled. Phone Security Code: This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code code: Master Reset Code
The default security code for Nokia is 12345 I need the IMEI (International Mobile Equipment Identity) number. Type this code in your phone to get it: *#06# you can also find it beneath the battery. Then I’ll give you the Master code to reset your Security code.
"Confucius he say: He who sits on tack is better off."
Put the airtell card in the phone and in the menu/settings/security/ and you will have either phone lock or phone security.
if you didn't change the code it should be 12345.
if that works swich it to; OFF
if it does not work your service provider will reset it for you.
Default security code is 12345 Unlock Code - is 5126700231 only if you have given correct IMEI no of your mobile and mobile model no ---------------------------------------------------------------------------------------------- Low feed backs hurt my ratings and I tried my level best to resolve the issue. so show your appreciation by rating it. Thanks for using fixya support..You have a wonderful day
