What kind of memory should I use? At present i am using PC3200 DDR.512MB. I upgraded it to 1 Gig but I resorted back to 512MB because my programs keep crashing. Is there any suggestions how I can upgrade my memory? thank you and more power.
yeah thats a normal issue with the dimension 2400 as the older bios only supports a max of 1gb of memory you will need to go to the dell website which ive linked below and get the bios update which will give you support up to 2gb-pc3200 ddr memory
Standard Memory
256 MB (removable)
Maximum Memory
2.0 GB
Memory Expansion
2 sockets
Memory Comments
PC3200 DDR SDRAM DIMMs
CPU Type
1.6GHz Intel Pentium 4
Model Comments
400MHz FSB
- Always believe HP - its there product - Staples is not the manufacture.
Memory type is the major problem with the 741GX chipset. Very touchy. I used Crucial PC3200 High Density memory to start with (2 x 1 gig Memory), system was lagging even though adjusted settings in bios. whenever a USB device was pluged in, the system would stop responding. Switched to low density memory and no problems since (Ultra PC3200 (2 x 1 gig Memory), and the USB device problem is also solved. I am running WinXP with SP2.
You Can Actually Upgrade This To 2 Gig Memory.
Each Slot Will Take 1 A Gig Strip.
I,d suggest Buying another 256 mb Strip, To Put Into Slot 2.
Or Buy a 512mb ( Half Gig ) Which Will Give you 750mb With your Existing Strip Already In There. ** Recommend 1 Gigabyte Max** 2 gig of Ram in This Baby Would Probably Start Glowing.
You Can Buy DDR/266/333 In 256/512/1 Gig Strips. These Are Commonly Known As SD-RAM-Modules.
the memory you're about to purchase will not work. the maximum gig that the computer can handle per stick is only 1 gig. this system is not designed for 4 gig barrier.
