Question about Bosch Washing Machines
Have bosch classixx6 1200 express which has frozen displays a flashing key and 36 will not budge, desperate Molly
Posted by mollygallucc on
Karl Wright
    President:
  • 1,653 Answers
Simply press and hold the Start button for 4 seconds and the childproof lock will turn off - the key symbol will disappear from the display.
If you want to activate the lock then press and hold the Start button until the key symbol appears on the display.
Posted on Oct 23, 2009
1) We are trying to install a Breeze 36 shower stall and don't understand the instructions. We are about to attach the fiberglass walls.
What molly bolts are you talking about. A molly or molly bolt, often misspelled moly,[1] is a formerly trademarked[2] name for a specialized screw fastener used with drywall, as a hollow-wall anchor. Larger sizes permit reasonably heavy objects, such as shelving, flat screen-TV mounts or central-heating radiators to be attached to drywall in locations where there is no stud behind the drywall. For heavy objects, multiple molly bolts may be required.
. You can use adhesive to glue to walls. The unit must be level and square. The corners in your home are not 90 degrees but close.Please don't drill any holes in unit., unless directed to.Holes in-walls are hard to seal. Let me know what unit number your shower is and I will help you.
Mar 13, 2018 | Home
I have accidentally put the child lock on my washing machine but have mislaid my instruction manual. Please help.
A re-posting of a Fixya answer:
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
Feb 23, 2018 | Bosch Washing Machines
Bosch classixx 1200 express lights flashing
Bosch 1200 classixx express washing machine. Upon switching on my machine, a little while later all of the lights on the control panel were flashing except the Start button. I tried to push the buttons but there was not the usual sound made upon depression of any of the buttons. They continued to flash. I switched the power off and cleaned out the pipes at the front of the machine to eliminate any obvious problems. Please help
Dec 05, 2011 | Bosch Washing Machines
Bosch classixx 6 1200 express is showing a key symbol in the LED - when I switch on the washing time goes back to 0 and the alert sounds and I cant start the wash I dont know how to switch the key...
Hello, welcome to FixYa.
The Key symbol means the lock has been activated some how.
On most bosch of your class this is how you work it on & off.
Here`s how to deactivate it...
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly.
Thank you for visiting "fixya" for your washer solution inquiry.
good luck going forward.
macmarkus :)
Aug 19, 2010 | Bosch Washing Machines
BOSCH CLASSIXX6 1400 EXPRESS
i've just rung bosch with similar problem - they told me it's the child lock - you have to press and hold the start button for 5 plus seconds and it should go off - worked for me!
Mar 01, 2009 | Audiovox Bosch 718 World Cellular Phone
Bosch washing machine flashing red lights
all lights are flashing on bosch classixx express no thinh working no water intake door is locked what is the problem and can i do it myself
May 28, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Washing Machines Logo
463 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
