Computers & Internet Logo
Posted on Oct 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dvd rw not read my cam dvd
I hav compaq laptop with dvdrom but it can;t read my sony camcoder dvd
Anonymous
Level 3:
Guru:
  • Master 355 Answers
  • Posted on Oct 22, 2009
Anonymous
Master
Level 3:
Guru:
Answers
355
Questions
0
Helped
149885
Points
1285
Sony camcoder has small disk dvd
first you insetr the cd in cd rom
then from other video editor or video converter software conver your video to mpeg or wmv formate then check the video
or check the cd rom reads other dvd or not
I have a Compaq SR1650NX (Windows XP Media Center with MS Office 2003) computer. My DVD+RW will not open. I can open it manually but my computer does not recognize the DVD. If I change out the DVD+RW,...
There is nothing wrong if you want to replace it with generic or branded DVDrom drive. As long as compatible with your motherboard. If you are using IDE or UDMA cable you must buy IDE DVDrom drive but if it's SATA cable you have to buy SATA DVDrom drive.Good Luck
Compaq presario v2000 heating problem
nothing is wrong with ypur laptopmotherboard. i suggest you to use original charger. doublicate charger are not good for laptops .
Dvd rw not detected in Bios and not working V5535 Fujitsu
you could try removing the cmos battery in the bottom of the laptop look in manual to see how or you could install using usb external dvdrom set bios to boot from usb dvdrom first
3answers
Cd/dvd rom not reading
It's likely a laser alignment problem inwhich you will need to replace the hardware. However, I had a similar problem once with a notebook and found out that a tiny bread crumb was near the spindal making the cd in the drive off balance. Check liberally for any debris. Good luck!
1helpful
Acer pc not reading dvds or cds
You probably need a new cdrom.
Any laptop cdrom, cd/rw, dvdrom, dvd/rw, or cd/rw-dvd combo will fit in you laptop. All you have to do is remove the mounting hardware from the old one, and place on the new one. They are pretty easy to remove from the laptop, as there is only one screw from the bottom that holds them in.
3helpful
I need a new dvd rw drive in tsukuba Japan
My dvd rom wont play dvd only cd's
DVD/CD players use two different lasers. One to read DVD and one to read CD. Sounds like your DVD laser burned out. Lasers last about as long as light bulbs do.
DVD not working
get your dvd writer service or try cd lens cleaner spray or cd proir servicing the dvdrom.........hopethis will help you.....Sameeraryan
2answers
Need to fix my CD/DVD rom
hai
try to update the frmware of the dvd drive from the dvd drive vendor site.
Cd/dvdrom light is blinking all the time
Check first under my computer/computer if you can see the DVD/CD Rom drive.  If not detected, follow the steps on this link...
http://support.microsoft.com/kb/929461/en-us
It should work fine after reboot.
Hope this helps
Grand Canyon Tech
Grand Canyon Tech
