Buy a new television! This old dinosaur appears to be made to connect to a laptop only! No HDMI ports and no Composite Video connections that I can see. You would need an HDMI to Serial Port cable
tv.manualsonline.com > ... > Panasonic Flat Panel Television ... and free pdf instructions. Find the user manual you need for your TV and more at ManualsOnline. ... Panasonic TH-50PE8U Flat Panel Television User Manual ...
hi , you panasonic plasma tv maybe have more than one problems in the sub power supply # etx2mm704mgb & power supply unit # etx2mm704mgh or #etx2mm704mgn. you must check original one what # ? parts you buy on shop jimmy.com. good luck!
Hello
Your TV has no direct cable connector. You can connect it to cable via converter using SERIAL (D-Sub 9pin [RC 232] type connector wire from converter to your TV. It is designed so. High Density D-Sub 15 pin connector is used to connect this Tv with computer. OK.
hi,
In your tv there some problem with power supply. you have to check the followin voltages. Sub 5v SOS ,Main 3.3v SOS A-Board,DTV 9v SOS , Tuner Power SOS. If any one of the voltage fails it will shows 10 blinks.
ok
You can buy an HDMI to DVI adapter (around 20$) to connect your HDMI computer cable to your TV. You will need separates audios cables, right and left, to bring the sound to the TV.
