Master
- Posted on Oct 22, 2009
Re: Dont no how to connect the internet to a psp go
- With your Psp turned on go to the “Settings” in the menu (scroll to the left)
- Scroll all the way down until you have reached “Network Settings” and click the “X” button to enter
- Select “Infrastructure Mode” and hit “X”
- Select “New Connection” and hit the X button again
- Now you will have a number of options for connecting to a wireless
connection. Choose “Scan” and press the control pad to the left, the
PSP will now scan for wifi signals around your area
- When the PSP finishes scanning you will probably have a few
different wifi connections. SSID is the name of the connection, the
Security column tells you whether or not the connection is password
protected, and the last one is the signal strength the higher the better
- If you want to borrow your neighbors unprotected wifi select a
connection with “None” in the Security column and a strong signal. If
you want to use a secure wifi than you will need to know the password.
Select one and press the X button
- Now the Psp will confirm your settings proceed by pressing left on the d-pad and save your settings
- Now test your connection if you are able to connect, awesome. If you were not able to connect try doing the settings again
- With the connection settings in place we can now connect the PSP to
the internet. In the home menu scroll all the to the left until you
have reached “Network” and go down to “Internet Browser” and hit “X”
- Your browser will appear, select the little square box to enter the
web address, play around with the different options. Have fun with your
PSP online
var addthis_pub="askabouttech";
