Question about Apex Digital GB5108 51" Rear Projection EDTV-Ready Television
Keeps changing channels on its own - Apex Digital GB5108 51" Rear Projection EDTV-Ready Television
Posted by saxon_0843 on
Chi Chu
  • Apex Digital Master
  • 8,457 Answers
Ur control button channels up/down button might stuck in pannel it self?Or the PCB control pannel itself it defective must be replaced.
Posted on Oct 22, 2009
The channels on my ge 32gt720 tv keep changing by them self
Channel change button on the remote or on the side of the TV coule be stuck.
Sony tv keeps changing channel
It sounds that the main system control memory IC is faulty.
My channels on my tv keep changing on its own everytime i turn on the tv. i tried new outlet, new batteries, and turned on manually. and left it sit for a week. but the channels keep changing on there own...
defective tac switch on the manual channel button, it is found inside under the button, this causes the program to change channel because the connection of the switch is shorted..normally it should be N.O. (normally open)...try to replace a new tac switch..
1helpful
Router keeps dropping connection
Solution for wireless dropping issue or connectivity issues
*Change channels on the router from1,6,11 or 9(rarely works) *Change Channel width 20 or 20/40 MHz *Keep other radio signal emitting or wireless devices away as possible *Change security types *Change Antennas position *Upgrade the firmware
Cannot keep all channels on tv
When you say you "lose" channels, you probably mean there's no signal there anymore but they are still in the channel memory. This is normal if you have a rotatable antenna. You need to mark the rotator (or just keep a chart nearby) with the heading for each channel.
If you mean you're losing channels from memory when rescanning after turning the antenna, the only solution I can offer is to record the channels found (and their signal levels) after scanning a direction. Then change directions and rescan. See what new channels have been found, what have been lost, or how signal level has changed on common channels. Then you can manually add whatever you need, and you'll know what direction is best for each. It's tedious, but you should only need to do it once.
2helpful
2answers
Talk about frequency change
To change channel & code press talk and monitor while turning radio on. Radio will speak current channel. Release both talk and monitor. Press talk to change to next channel or press monitor to keep current channel. Press monitor when desired channel is selected, radio will speak current code. Press talk to change to next code or press monitor to keep current code. Press talk to change code as desired then press monitor when done. Will speak channel and code selected. Set all units in same manner to communicate.
My tv keeps changing the channels on its own
take out the batteries of all the remotes that are able to change the channel and put a piece of duct tape over the infared reciever and if it still does it, it is most likely defective.
thanks,
Nate
2answers
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Apex Digital GB5108 51" Rear Projection EDTV-Ready Television Logo
Top Apex Digital Televison & Video Experts
Ekse
 Francisco Mauricio...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
