Question about Dual Electronics XDM6350 Car CD/ MP3 Player
Car stereo not working and dimmer lights went out
Posted by cody_s_gilbe on
Anonymous
    New Friend:
Where is the switch so i can dim down the blue light from my stereo? and, how do i turn on the stereo beep?
Posted on Mar 19, 2011
Is there a fuse in the factory stereo of the Honda Accord?
There are two fuses, all in the fuse box. One for the radio itself (which probably is the one that went out) and another one for the night illumination, which works together with the dash lights / dimmer.
The one for the radio is on the passenger side fuse box. Look in the manual for the right location, I think it is #12 or 13
Dec 15, 2015 | 2001 Honda Accord
I have a 98 Honda accord I installed a stereo and now the speedomoter lights won't light up?? How do I fix this?? Also the lights on the shifter went out.
There is a dimmer switch to the left of the steering wheel that controls this and also controls the lights in your factory stereo, first make sure it is turned on and your headlights are on, turn up the relay dimmer. If this doesn't work, ask the person that hooked up your stereo to retrace his steps as the stereo may have been the common connection for this and now removed it won't complete the circuit.
Jul 07, 2014 | Cars & Trucks
What is the pink wire for in the stereo of a 2006 Hyundai Santa fe? and what do I connect the dimmer wirefrom the santa fe to in a new stereo
The pink wire from the stereo unit is often the dimmer wire, and is connected to a power feed from the vehicle's side lights. Not all stereos have a dimmer function however, and may not have this wire available.
Nov 04, 2012 | 2006 Hyundai Santa Fe
Canter console lights do not work after i installed a sony stereo
remove wires till you find the one with problem them repair problem
Jul 29, 2012 | 2006 Toyota Corolla
Dash Instrument Panel Lights are dead - gauges work fine
do you have taillights? most of the time there on the same fuse. also chk. to see if plug is all the way in on your headlight switch.
Jan 21, 2009 | 1993 Buick Park Avenue
New radio installed - now dash lights don't work
Most factory stereos are wired to the dash dimmer switch. Usually if the dash lights go out after an after market stereo installation, it is because the wire that originally went to the factory stereo is not used for after market stereos. Double check the fuses and ensure the wire that controlled the lights on the factory stereo is not grounding out on something.
Nov 11, 2008 | 1998 Honda Passport
Color diagram for speakers
1995 Ford Windstar Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Green/Violet
Car Radio Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Brown/White
Left Rear Speaker Negative Wire (-): Light Brown/Yellow
Right Rear Speaker Positive Wire (+): Light Brown/Green
Right Rear Speaker Negative Wire (-): Brown/Pink
Oct 24, 2008 | 1995 Ford Windstar
Car stereo
First make sure you haven't turned the dash lights down so low that you can't tell that they are on. After that look for a wire coming from your headlight switch that is disconnected. Your headlight switch is also a "dimmer" switch and a separate power wire is probably required to operate this dimmer switch connected to your dash lights (including the lights in your stereo) you have probably ran this variable wire to your stereo and inadvertantly disconnected your dash lights.
Dec 23, 2007 | Car Audio & Video
Dim Display
On newer stereos, you might have to experiment with the "panel" wire.
I just installed a VR3, and discovered that the more voltage on the "panel" wire, the dimmer the display.
With no connection, you get full (daytime) brightness. With full voltage, you blank the display.
I wired mine up to the car's instrument lights through a 10Kohm trim resistor so I could adjust the "night" intensity. But if I dim the car's instrument lights, the stereo gets brighter. Oops.
Older car -- I can't just flip a software bit. ;)
But I gather a lot of new stereos are like this. The display on my (factory) stereo in the Mitsu dims a fixed amount when the lights come on, but doesn't adjust with the car's instrument dimmer.
Sep 23, 2007 | Car Audio & Video
Dual Electronics XDM6350 Car CD/ MP3 Player Logo
360 people viewed this question
Top Dual Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
