The refrige/freezer is about 6 years old. It is cold in the freezer but not cold enough to freeze..The temperature dial is now set on coldest This condition came on suddenly. It has been fine up until now.Thanks
Not enough info. Age, freezer temp. Runs all the time or not ect. Tell us the story.Not enough info. Age, freezer temp. Runs all the time or not ect. Tell us the story.
You can't post conmments that contain an email address.
The refrigerator portion is fed cold air from freezer section to cool it. Check for the freezer fan and/or the damper mechanism that directs air into fridge compartment for proper operation.
check yor damper door, it's the little door at the top and or bottom of the fridge insid near the top and or at the bottom behind the crisper drawer when working right they open to let cold air in from the freezer and warm air out. top one cold in, bottom one warm air out.they work on a sensor/relay when the freezer fan goes on they open when cold air is needed.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp. The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
2 possible issues. freezer fan is not working ,should be able to hear it inside frz.2nd issue auto defrost is not working, look for ice/frost build up on rear wall of frz.possible timer or heater issue Hope this helps ,pleases rate my response :)
I have a side by side jenn-air refrigerator, the freezer compartment working fine and making ice like it should, however the refrigerator compartmant is not cooling, no cold air is felt, I need advise.
Thanks
