Palm Treo 680 Smartphone Logo
Question about Palm Treo 680 Smartphone
How do I change the language to my palm treo 610
How do I change the language to my palm treo 680
Posted by sdominick on
Anonymous
    New Friend:
Remove the battery and Insert then change the language settings.
best luck.
Posted on May 08, 2010
I WANT TO CHANG THE LANGUAGE ON MY PHONE TO ENGLISH. PALM TREO 750. ITS IN FRENCH AND I WANT TO CHANGE IT TO ENGLISH
Try a hard reset (settings will be reset).
Then you might be able to choose a different language.
I've English is not listed.
Read this on how to change the firmware to English:
http://discussion.treocentral.com/treo-750/127490-change-750-english-os.html
Palm treo is in spanish how do i change to english
  • Check if your handheld supports multiple languates. Your product manual may contain information about changing languages. If it does not, you may wish to find out if your handheld supports multiple languages by performing a hard reset (be aware that you will erase all data from your device when you do a hard reset). On the startup screen after the hard reset, you may be asked to select a language. If you asked which language you want to use, select a language and install a localized Palm Desktop (below). If you're not asked, your device does not support multiple languages.
  • 4helpful
    2answers
    3helpful
    I want to change language
    unfortunately you cannot just switch languages on the treo or really any Windows Mobile Treo or Palm
    They release the phones with one language installed in whatever country and thats about it.
    You can buy a Treo 750 in english, but not change the language
    Language settings
    Bueno, trata lo siguente:
    If you purchased the Treo in the U.S., you should have the English to Spanish option when you reset the phone. Just make sure to back up your data before resetting it.
    HotSync the Treo 650 to your computer to ensure that you have all of your information backed up. You will lose everything on your Treo 650 with a hard reset.
    Step2Press and hold down the red phone key on the right side of the Treo 650 keyboard until the Palm screen appears. This will begin the hard reset. Step 11Let go of the red phone button when you see the Palm screen. Step 2Read the screen prompt carefully. It will ask you to press the up arrow key to proceed with the hard reset or the down arrow key to abort. Press the up arrow to continue with the hard reset. Step 3Wait for the phone to reboot. When it comes back on, it will ask you to select a language and walk you through the same introductory screens you saw when you first got the phone. Step 4HotSync your Treo 650 to your computer. When prompted, select your old username to restore all of your contacts and information. This should complete the hard reset process. jQuery('.Article .Steps .Image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • Do not forget to back up your data before performing the hard reset. If you don't, only the data from your last HotSync will be able to be recovered.
    • After performing a hard reset, install your applications one at a time to make sure each is in working order. Delete any applications that are not in working order, as those might have caused the need for the hard reset in the first place.
    Buenas Suerte,
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks,
    Joe Diaz
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Change language on treo 500
    Well you will have to perform a Hard reset on the device to resolve this issue. Once the Hard reset is done you will get a prompt to select the language in the options.
    Follow the below link to perform a Hard reset on the device.
    http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=134,E=0000000000194614156,K=2371,Sxi=18,Case=obj(887)
    Treo 650 change from chinese characters to English
    try doing a hard reset and it should give you language options after that, if its not giving you language options,the rom might be chinese only,you need to flash the rom to an english version.
    Palm Treo 600
    Do a hard reset by holding down the K and return key, and at the same time push the reset button on the back. Plug in the charger to turn it back on. You can then start over by selecting english.
    Change language to english
    We send the second List (Cash-Report from 30.04.2008). Beim festen Vorschuss haben wir per 30.04.2008 CHF 200'000.00 zurück bezahlt.
    Mit freundlichem Gruss
    2answers
    Palm treo 750
    i think you get the option to choose your language after a hard reset? if you wish to do that. make sure you have done a hotsync
    Top Palm Computers & Internet Experts
    Marvin
    Marvin
    NOEL
    NOEL
    Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
