Question about Samsung WF448AAP Front Load Washer
After my washer spends the rubber comes
After my samsung front load washer spends the rubber comes off track and the washer leaks
Posted by jaronicabear on
Ash
    Novelist:
  • 154 Answers
Do you mean the door seal has come loose.
Disconnect the machine from the power. Open top hatch by removing two screws in the back and sliding top lid back and up to remove.
Check down from the top of the machine and feel around the door seal. Make sure there are no holes or tears in the seal. Try and refit seal. there is a metal ring around the drum and also around the front panel where the door seal joins. Make sure the are tight and fit in properly.
Let me know if I didnt understand the problem.
Good luck.
Ash
Posted on Oct 22, 2009
Why won't my Samsung Front Load Washer Model # WA45H7000AW turn off automatically?
Samsung Top Load Washer WA45H7000AW/A2 ' Front ...
www.samsung.com > ... > Top Load Washers
Samsung Electronics Rating: 3.9 - ‎254 reviews - ‎$699.00
4.5 cu. ft. Capacity. Washer capacity has a direct impact on how much time you spend doing laundry. ... Top Load Washer with VRT (White) ... Owner's Manual.
Oct 16, 2015 | Samsung Washing Machines
I am having a problem with my front load washer leaking water once the cycle starts.
I had this problem with mine a while ago and it wound up being a rubber seal inside the machine. I had to have the serice tech come and repair.
Jul 19, 2010 | Samsung WF337AA Front Load Washer
Maytag MAH2400A Front Load Washer
likely a rubber gasket slipped off the groove.... try taking it apart and slipping the gasket back on.
heavy loads have more force during the spin cycle.
Apr 20, 2009 | Maytag MAH2400A Front Load Washer
Rubber is off it's track and water leaks out during the wash
remove the spring and reseat the gasket, then replace the spring clamp spring side down. this part will be kind of tough but may help to wet it to make it slide on. not doing this will cause leaks
Mar 25, 2009 | Kenmore Elite 45986 Front Load Washer
Leaking front loader
If your washer has a rubber seal around the inside of the door and it has a little opening where the detergent comes into the washer put your hand inside the rubber piece and feel all the way around and see if you feel any holes or cracks in it and that is where it will leak from.
Dec 03, 2008 | Kenmore Elite 45986 Front Load Washer
Leaks water onto floor in front of washer after spin cycle, help
open the door though, put your hand around the rubber boot assy, run *** all around looking for small tears, and or holes, if so replace it. only other thing to do is remove the lower access panel and watch it spin a load and youll be able to detect where te waters coming from
Mar 22, 2008 | Kenmore Elite 45986 Front Load Washer
Washer Probem.. the rubber came off the metal rim.
The rubber is most likely damaged and needs replacing. They make and sell repair kits to fix this. Buy the repair kit from any Bosch dealer and the instructions are included in the package.
Nov 24, 2007 | Bosch WFR 145 Front Load Washer
Samsung WF448AAP Front Load Washer Logo
350 people viewed this question
Top Samsung Washing Machines Experts
Marvin
Marvin
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
