Washing Machines Logo
Posted on Oct 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I wash dark clothes, I get lint on them or white spots
Kevin
Level 2:
  • Expert 79 Answers
  • Posted on Oct 22, 2009
Kevin
Expert
Level 2:
Answers
79
Questions
Helped
74913
Points
285
The lint is from some other garment in the same wash.
Do the white spots wipe off or are they "bleach stains"?
Assuming they wipe off, then your detergent is not dissolving all the way. Make sure the water is hot enough. Even cold water needs to be a minimum temperature and during the cold months the water can get too cold. Try warm or mix hot and cold by changing back-and-forth on the control for the wash temperature. Also, try putting the detergent in first or buying a higher grade of detergent (i.e. Tide). Best of luck.
If this information was useful, please select YES to the first two rating questions. Good Luck and thank you!
5 Related Answers
Anonymous
  • 146 Answers
  • Posted on Oct 31, 2007
SOURCE: Dark Spots on clothes
There may be some pieces of mat stuck between the inner and outer drums. The quickest way to remove this is to remove the drain hose that leads from the drum to the pump and feel around the bottom of the outer drum and remove any foreign objects that may be stuck in there.
A
Anonymous
  • Posted on Jan 13, 2008
SOURCE: Wasing machine leaves rust spots on clothes.
My kenmore washer basket has noticable chips on the inside and has rust stains as well, it is only 5 years old. how can I find out about the 10 year warranty?
onthejob5130
onthethejob1
  • 640 Answers
  • Posted on Feb 07, 2009
SOURCE: Lint on dark clothes in my Whirlpool Cabrio washing maching
sorry there right ..your not using he or low suddsing detergent ,or your using to much..as the water pumps out of unit the sudds stick to side of tub than when rinse water comes in it washes back on your clothes...i can only give you tips and something to look for...look for water not drainning fast enough ,,cut down on detergent,,wash your dark clothes first..give your unit a bleach clean about a pint of bleach..keep me posted onthejob
Anonymous
  • Posted on Oct 26, 2009
SOURCE: lint showing up on dark clothes
lint
Anonymous
  • 13 Answers
  • Posted on Feb 05, 2010
SOURCE: after wasing dark cloth, there a lint on them, how
i think the paint inside the washing machine started to peel,and maybe that's the cause of white lint.
http://www.washingmachineadvisor.com/1400-spin-washing-machine
Our washing machine is occasionally leaving small dark brown spots on clothes. What are these spots and how do we stop this? They are very difficult to impossible to remove!
Find and clean the lint filter (s). This needs to be done every 4 or 5 loads of washing. If not done it builds up goes black and the slime that grows is like a grease. Hpefully you can use one of the enzime cleaners on the affected clothes.
Washer leaves white lint like spots all over dark clothes.
This happens to me as well but only when I overload my washer or when my washer needs to be ran thru its cleaning cycle.
Whirlpool stylemaster 4217141 rev
Try cleaning the lint filter on the bottom of the inner opening. Lift up and clean filter.
My Kenmore 22642 washer is leaving lint all over the clothes. If i run them through the dryer, that will remove the lint... but some of my clothes don't go through the dryer. I can't seem to determine if...
Wash clothes separately whites and light colors together. Darks with liquid detergent. No lint filter on the machine. I have found some powder detergents do not dissolve completely.
After wasing dark cloth, there a lint on them, how
Can i put both whites and colours in a tumble bryer?
Yes, with two caveats. 1) If you put in a dyed fabric that is leaching dye you might get stains on the whites. Anything that has been washed more than three times before should be safe enough. 2) You may end up with some dark lint on your white clothes. You may want to avoid dark clothes that produce a lot of lint, like towels or sweatshirts.
Oct 11, 2009 • Dryers
5helpful
Deposits on clothing
Be sure to seperate lint givers with lint taker, do not mix towels etc with clothes that are attracted to lint. Also be sure water levels are sufficient
Top Washing Machines Experts
john h
