Question about LG WM2688H Front Load Washer
Drumlight won't turn off then locks down the system.help
Posted by death2elves on
Jan McZeal
    President:
  • 632 Answers
  1. Press the SPIN SPEED and SOIL LEVEL buttons simultaneously.
  2. Press the Power button, while in the above condition. Then buzzer will sound twice.
  3. Press the Start/Pause button 15 times.
  4. The unit powers off.
Posted on Oct 22, 2009
I went to start my car and I cant turn the key. now my shifter wont move either. please help I have no idea what is wrong
Try to turn the key while moving the steering wheel. Sometimes the problem is in the lock system of the steering wheel.
Here you have several youtube tutorial where a "can't turn key" problem is solved:
Key won turn How to fix car truck or van ignition lock when can turn wheel...
How to fix ignition key that doesn turn Opel
How to unlock your steering wheel
Ignition Won Turn Key Several Reason Why This Happens EZ Auto Remote
You can find more tips searching in google for
start car can't turn key
Jul 30, 2015 | Saab 1998 900 SE
Anti theft is on and car won't start
put key in drivers door, turn to lock and then to unlock and try to start, if it still does not start use a different key.
Oct 26, 2012 | Ford Cars & Trucks
Convertible top doesn't open all the way
first let the system cool down if you try to open it and it was blocked by those hats because the hydraulic system have some thermal sensors .if after 30 minutes is still not working check the level of hydraulic oil (not the one from the steering ) i must be somewhere in the back of your car depending the model .U can also try to help a little with your hand but don`t apply extreme force ,just help it on the move especially on the last part where is not working well
Jan 22, 2018 | 2006 Volkswagen New Beetle
How do you turn off the FPA lock on the RCA TRUFLAT TV? I Can't access menu.
Hello
First of all, you must ahve its original remote control to unlock FPA lock. If you have it, go through the folloing steps.
* Hold down Menu button on the remote control, and the Volume Down button on the at the same time for at least 4 seconds. "The set won't say so, but the lock will be released".
** Hold down Zero button on the remote control, and the Volume Down button on the TV. The set won't say so, but the lock will be released.
*** Hold down Menu button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. The set won't say so, but the lock will be released.
Mar 11, 2012 | RCA TruFlat 27F520T 27" TV
I have a Maxx Classic WAE20261AU/01 front loader. The machine won't start because the door won't lock. The door has been playing up a bit for about 2 months, but now it won't lock at all. It is...
Sorry. It seems that I have fixed it by using your solutions!
I drained it and cleaned the filter thing down in the bottom right hand corner, put it back to gather and then it turned on again!
Interestingly I found a bobby pin down there!
Thanks for your assistance John_Cross!!
Jun 21, 2011 | Bosch Washing Machines
Xterra will not turn on. windows won't roll down, doors stays locked. won't roll over at all. odometer won't come up
Do you get any dash lights when you turn the key on? If not, you could just have a dead battery.
May 27, 2011 | 2000 Nissan Xterra
My LG ht303su dvd player won't eject and it says it's locked
my LG ht303su DVD player won\'t eject and it says it\'s locked
Jan 15, 2011 | LG HT303SU Theater System
Security lites won,t shut off have to disconnect battery
Try turning the door key in the rear door hatch lock, lock-unlock-lock. That should shut down the factory security system.
Jan 13, 2011 | 1995 Jeep Grand Cherokee
Lock won`t open
Look for a button or sensor which turns the light off or which the door would press when closed.
If you find it hold it down for a minute, then let go this should reset the lock
Aug 13, 2008 | Frigidaire FEF352 Electric Kitchen Range
LG WM2688H Front Load Washer Logo
239 people viewed this question
Top LG Washing Machines Experts
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
