Samsung SPH-m520 Cell Phone Logo
Question about Samsung SPH-m520 Cell Phone
I just want to completely disassemble my phone. how do i do it?
Posted by curious_g713 on
  • David Fankhauser
    David Fankhauser Aug 04, 2013
    After removing the four screws, the back is held by more than sticky foam (I did not see any foam). There are two plastic clips in the front which must be pryed towards the top of the phone (I broke one, unknowlingly). Worse, there is SOMETHING at the bottom of the back which will not yield. If I find out how to complete removal of the back, I will let you know. Any suggestions?
Anonymous
Start by removing the battery and the four small Phillips-head screws around the battery. Next, remove the plate on the back of the phone, below the battery panel. The panel is stuck in place with sticky foam and might be hard to peel off. Then remove the two small phillips-head screws. Next use a tiny (glass repair kit) flat-head screwdriver to pry the two halves of the base apart at the seam.
This is where it gets tricky. Gently take each piece off one-by-one. But to separate the screen you have to slide it half way and hold it in place while you unplug the ribbon cable from the circuit board in the base of the phone. Then disconnect the arm from the slider and slide the phone open to remove the two screws behind the silver stickers on either side of the camera "shutter". Now pry the slider housing apart as with the base.
Posted on Nov 12, 2009
I have an Infotainment Mega Power Bank and the flashlight will not turn off! Help!
you can get guide from many sites.. i know few
error codes/ fault codes, wiring diagrams, schematic diagrams, torque specs, engine info, switches functioning, assemble, disassembly, complete refurbish, repair, installation every single thing is covered
within seconds u can get the access and it's totally illustrative complete
Jan 19, 2019 • Cell Phones
How to set up uconnect phone on my jeep patriot ?
i know few
How to Fix an iPhone 5 Screen?
Phone has to be completely disassembled. There are numerous small screws if differing sizes. Watch a YouTube video before attemoting. First time plan on an hour or 2 with electronics repair exlerience.
Oct 18, 2016 • Cell Phones
How do I completely disassemble my Devour?
Brennon
There are sites that cater to teardowns. I can't recommend taking your phone apart.
Mark
Motorola Support
1helpful
Hi i need someone to help me on how i can replace the housing of my nokia n91...i already have the new casing with me...
HI. Follow the link. It is a complete video regarding disassembly of Nokia n91 phone.
http://www.youtube.com/watch?v=UDEl4pzmyaE
May 09, 2011 • Cell Phones
How to remove nokia e72 panel.
Squeeze the bottom of the back pannel on both sides and it should release.
http://thenokiablog.com/2009/04/26/how-to-disassemble-nokia-e71-replace-faceplate/ This is a walk-through on how to completely dissemble the phone.
3answers
My mobile is damage by water how can i solve this problem
Get the Phone Out of the water. Do NOT power it on.
This may sound too obvious a step but a few extra seconds that your phone spends in water can reduce whatever chances you had of saving your phone.
If however your phone has spent more than a few minutes in water try removing the battery when the whole gadget is under water itself .
Powering up the phone when it is wet causes the maximum damage to your phone.
2 Remove the battery and SIM card
Water + battery is a bad combination for your phone. Remove the battery as soon as possible. SIM card too must be removed immediately as water on SIM cards may erase all your contacts stored in the SIM.
3 Dry the phone as much as possible
Try and pat dry the phone, the battery and the SIM card. Using a paper towel is advisable for removing water quickly.
4 Metciulously Disassemble the phone completely
This is one of the most important steps on your phone's path to recovery. If possible take your phone to a local mobile phone servicing shop and ask him/her top disassemble the phone completely for you. Make sure the circuits are not powered up by the shopkeeper.
If you are worried that disassembling the phone will make your warranty/guarantee void you need to know that phones come with Water Damage indicators which change colors with the slightest hint of water. No phone warranty covers water damage.
5 Dry all the phone components with a dessicant
After disassembling the phone immerse each component in a bowl of uncooked rice / silica gel packs. These dessicants absorb water effectively and draw out water from all nooks and corners of your phone. Heating / Vaporising the water is a bad idea cause that would leave salts on your phone's circuitry and cause corrosion and eventual death of your phone. Hence drying with uncooked rice/silica gels where water is removed by absorption is the best option. Leave it there for a couple of days.
6 Show patience and let every component lie under a table lamp for a couple of days
Now your phone is almost on its way to complete recovery provided you show Adequate patience. You may keep the bowl of rice under a table lamp for this duration . Changing the rice /silica gels though not a mandatory step, can be pretty effective and useful.
7 Assemble , Pray and Switch on!
My blackberry screen is completly white no error messages or anything and the phone isnt working either????
Hi,From your problem i think the phone's screen is bad and it probably needs to be replaced,you can get a detailed solution on how to disassemble your phone and also the price and the purchase of the screen at the link provided below;
http://www.formymobile.co.uk/disassembly.php
Thanks and take care
Sonyericsson s500i
http://www.youtube.com/watch?v=triByPUE0vs&translated=1     this video is a complete disassembly.
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Steve
Tim Whalen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
