Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Cant load software to add new user put CD in laptop and follow directions to add printer get a no driver answer from computer.
Posted by carolho38 on
mike roark
  • Konica Minolta Expert
  • 158 Answers
Install the driver as a local printer then go to the properties of the driver and click on the ports tab and click on add port click on standard tcpip and then new port enter the tcpip address click on lpr and enable byte counting and the print queue name is print click ok and apply it should print after that
Posted on Oct 23, 2009
Need to install mcafee antivirus without a disc
Install McAfee Antivirus Software
# Step 1:
Purchase a new copy of McAfee Antivirus software from your nearest computer retailer or check online at the McAfee site for a downloadable version.
# Step 2:
Load the software according to manufacturer's directions.
# Step 3:
Go to "Start," "Control Panel" then "Add or Remove Programs." If the McAfee Antivirus Software is there, you will need to select "Change." The directions will allow you to put on the updated version. For a new product, follow the next step.
# Step 4:
Place the CD into the appropriate drive. Select the installation button so that the program will load into the computer.
# Step 5:
Restart the computer after the installation. Following the directions given, select the options you want to make your program user-friendly for your use.
# Step 6:
Enable the system to select specific times to automatically scan your computer for viruses.
# Step 7:
Start your computer to enable all of your changes to take effect.
Dec 17, 2010 | Mcafee AntiVirus Plus 2011 1 User
Tip
INSTALLING A PRINTER IN WINDOWS 7
To install a printer in window 7, you need the printer installation CD/software.
Connect the printer to your system via a USB Cable (or any other cable necessary). Power on the printer. If you use a USB cable, windows 7 will automatically detect the printer and try to install it for you. However, if windows 7 does not have the driver, you will be prompted to load the drive from CD or a file location. If you have the Driver CD, load it now or browse to the folder where the driver software is located and load the software. Follow the on screen instruction to complete the installation.
Also
From start------devices and printers ------ add a printer ------add local printer ----- use an existing port, next ----------choose the printer manufacturer and the printer model. If not on the list and you have the installation CD choose have Disk and then next. Follow the onscreen instruction to complete the installation.
You can also run the Printer driver software and follow the onscreen instruction to complete the installation.
on Jul 01, 2010 | Computers & Internet
How to install mcafee antivirus interet security 2011
Get step by step instructions to install Mcafee on your PC
1. Load the software according to manufacturer's directions.
2. Go to "Start," "Control Panel" then "Add or Remove Programs." If the McAfee Antivirus Software is there, you will need to select "Change." The directions will allow you to put on the updated version. For a new product, follow the next step.
3. Place the CD into the appropriate drive. Select the installation button so that the program will load into the computer.
4. Restart the computer after the installation. Following the directions given, select the options you want to make your program user-friendly for your use.
5 Enable the system to select specific times to automatically scan your computer for viruses.
6. Start your computer to enable all of your changes to take effect.
Nov 29, 2010 | Mcafee Internet Security 2011, 1-User
How to install mcafee antivirus licesend copy
Follow the given instructions to install McAfee antivirus on your PC:
1. Purchase a new copy of McAfee Antivirus software from your nearest computer retailer or check online at the McAfee site for a downloadable version.
2. Load the software according to manufacturer's directions.
3. Go to "Start," "Control Panel" then "Add or Remove Programs." If the McAfee Antivirus Software is there, you will need to select "Change." The directions will allow you to put on the updated version. For a new product, follow the next step.
4. Place the CD into the appropriate drive. Select the installation button so that the program will load into the computer.
5. Restart the computer after the installation. Following the directions given, select the options you want to make your program user-friendly for your use.
6. Enable the system to select specific times to automatically scan your computer for viruses.
7. Start your computer to enable all of your changes to take effect.
Nov 01, 2010 | Mcafee Total Protection: Windows
How do I change the ip address of the Dell 1720 dn printer to work with my network?
Ok the following instructions will help you reset the ip address of your printer however you must use the origina driver cd to do this. Follow the instructions below if you have no print server involved with this network. If you do use a print server let me know ok?
Print and Check the Network Setup Page
  1. When the Ready/Data light is on solid, press and release Continue to print a menu settings page and a network setup page.
  2. Under the Standard Network Card heading on the network setup page, make sure Status is Connected.
If Status is Not Connected:
    • Make sure the Ethernet cable is firmly plugged into the back of the printer.
    • Plug the Ethernet cable into another wall outlet.
  1. Under the "TCP/IP" heading on the network setup page, make sure the IP address, netmask, and gateway are what you expected.
  2. Ping the printer and verify that it responds. For example, at a command prompt on a network computer, type ping followed by the new printer IP address (for example, 192.168.0.11):
ping xxx.xxx.xxx.xxx
If the printer is active on the network, you will receive a reply.
  1. If your printer doesn't respond, or if the IP address is not what you expected:
    1. Insert the Drivers and Utilities CD into your computer.
    1. The Drivers and Utilities CD should launch the installation software automatically.
If the CD does not automatically launch, click Start® Run, type D:setup.exe (where D is the drive letter of your CD), and then click OK.
    1. When the Drivers and Utilities CD screen appears, click Set IP Address Utility.
    2. Select your printer from the "Configure Print Servers" list, and then click TCP/IP Settings.
    3. Make the necessary changes, and then click OK.
    4. Click Close.
    5. Print and check the network setup page to verify your changes.
Install Printer Drivers for All Clients
  2. The Drivers and Utilities CD should launch the installation software automatically.
If the CD does not automatically launch, click Start®Run, type D:setup.exe (where D is the drive letter of your CD), and then click OK.
  1. When the Drivers and Utilities CD screen appears, click Network Installation - Install the printer for use on a network.
  2. Select Install printer on one or more remote computers, and then click Next.
  3. Enter your Administrator user name and password, and then click Add.
  4. Select the clients or servers, and then click Next.
  5. Select the network printer you would like to install, and then click Next. If you do not see your printer listed, click Update to refresh the list or click Add Printer to add a printer to the network.
  6. Select your printer from the list. If you would like to change the printer name listed, enter a new name in the Printer Name field.
  7. If you want other users on the network to access this printer, select Share this printer with other computers, and then enter a share name that users will easily identify.
  8. Click Next.
  9. Select the software and documentation you want to install, and then click Install.
  10. When the Congratulations! screen appears, print a test page to verify the software is installed correctly.
  11. Click Finish to exit.
Aug 09, 2010 | Dell 1720dn Laser Printer
No software disk to load 1700 into Dell 6400 Inspiron laptop.
In Windows, how do I install my printer? Most new printers, especially USB printers, come with installer programs. If you have neither installation instructions nor an installation program, you can use one of the following procedures to install most printers:
USB printers (Windows 98, Me, 2000, and XP only)
  1. Make sure that the USB cable is unplugged from your computer and your printer. USB devices work differently from older devices and usually need to have the drivers installed before you connect the device.
  2. If you have an installation disk, insert it into the drive. If there is an installer provided, it should run or be executed here. Follow its instructions, and it should take care of installing your printer in a few moments.
  3. If you don't have an installation program, plug the USB cable into your computer and your printer. This should trigger the Add New Hardware Wizard.
  4. Click Next, and then select Search for the best driver for your device. Click Next.
  5. Uncheck all options except Specify a Location. Click Browse. Browse to the disk, CD, or directory where your printer drivers are located. Click OK, and then click Next twice. Note: You can download some drivers from the web. Consult the web site of your printer's manufacturer, or see Where can I find driver updates for my Windows computer?
  6. When all the files are copied, click Finish.
  7. Turn on your printer. Windows should detect the printer's presence and finish the installation. If the option to print a test page is offered, do so. This will confirm the installation. Click Finish.
Jan 06, 2009 | Dell 1700n Laser Printer
Lexmark Z1300
Hi laq,
I'm not sure if it was me who answered your ?, I'll assume not, try it this way once:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop(watch for the light yellow bar at the top of window viewing pane, click on this and choose – download file - . Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done.
anaanymous
Oct 18, 2008 | Lexmark Office Equipment & Supplies
I try to print from Microsoft Word or the internet or any other program and its not printing anything i tried everything! i even did the test to see if something is plugged and it did fine and printed but...
This is most likely due to a driver fault. The "driver" is just a small piece of software that lets a computr communicate with other devices (peripherals). Disconnect the printer and put the CD in the computer (the CD that came with your printer) and follow the instructions. If no instructions or interface loads on the screen when you insert the CD then simply connect the printer to the computer...when the message box prompts you to specify what was connected to the computer, then browse for the driver by directing the brose option to the CD drive where the driver is located. If this fails or if it is too hard to do, then go to the canon website and go to their support page. Here you can download drivers for your inkjet by searching for the model. Once you have the corrct driver installed then:
  1. In Windows XP, click Start, and then click Printers and Faxes.
    In Windows 2000, click Start, point to Settings, and then click Printers.
  2. In Windows XP, under Printer Tasks, click Add a printer. In Windows 2000, double-click the Add Printer icon.
  3. Follow the instructions in the Add Printer Wizard. If you want to print a test page, make sure the printer is turned on and ready to print.
Jul 04, 2008 | Office Equipment & Supplies
Scanner does not work
First make sure that the scanner drivers and all the PSC drivers have been installed.
Or try to reinstall the printer drivers by removing all Hewlett Packard's applications from "add - remove programs" in the control panel. Then disconnect your printer and restart the computer.
When the PC finishes loading windows, insert the HP printer software CD while pressing SHIFT on the keyboard for 30 seconds. Connect the printer again and follow the "Found new hardware" wizard instructions. When a gray sandglass pops up, choose "Decline" or "Not agree" to the license terms and continue with the installation.
After that, try to scan again from Photoshop or another scanning program. Remember that in the reinstallation, you haven't installed the HP image zone software.
May 04, 2008 | HP PSC 950 All-In-One InkJet Printer
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
53 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
