Question about JVC HR-A592U S-VHS VCR
It won't turn on....it is plugged in and everything is attached and the same plug in has the tv working but not the vcr
  • 975 Answers
Check out the main fuse inside the power supply.
AJ
Posted on Oct 21, 2009
  • ALBERT GARCIA
    ALBERT GARCIA Oct 21, 2009
    check out the main fuse inside the power supply.
    AJ
6ya staff
SOURCE:
Sanyo DVW 7200 PS2 won't work
Tune the DVD/VCR to "channel 3".
Dec 18, 2013 | Sanyo DVW-7200 DVD/VCR
My hdtv visonquest just overheated and wont turn back on how to fix this?
follow this steps and fix it. God bless you
  1. Verify TV is plugged-in and getting power.
  2. Verify your home's power breaker has not tripped.
  3. Verify the batteries in the remote control are good.
  4. Verify you have selected the right input for Cable/Satellite, antenna, DVD, VCR or Game Console.
  5. Verify the cable/satellite box is plugged in and getting power
Verify you are getting cable/satellite in other parts of the house
However if everything is o.k the problem is power supply inside.
see the video attached.
Jul 31, 2013 | Televison & Video
Had power outage and now VCR/DVD does not turn back on. lights all work but it doesn't seem to pick up the channel?
Dis-connect the plug from the wall receptical and other leads attached to to the unit. Next press and hold power for too minutes in an attempt to reset the microprocessor, now hook everything back up and power on, if this fails it probably would be cheaper to replace the combo than have it repaired.
Jun 03, 2012 | Symphonic WV806 DVD Player/VCR
How do i hookup vcr to tv
The best way to hook up your VCR is to use the AV jacks (Red, White, and yellow). Plug into AV1 or Video 1 on the back of the TV. Then, plug into Red, White, and Yellow output jack on the back of the VCR. After everything is hooked up, turn your TV channel to AV1 or Video 1 to watch from the VCR.
To record, you'll have to plug your cable box or satellite box to the AV inputs ( Red, White, and Yellow) in the back of the VCR. ( The only thing is it wouldn't be in HD )
Nov 04, 2009 | Zenith Z50PX2D 50 in. Plasma HDTV
Hooking up my x-box 360 through Direct TV
Ok i had it installed today too....i already had it so i have experience with it....get a vcr....in th eback there should be some ports for AV cables hook that up and get one of those cords that look like the direct tv cords and put that in you VCR out to tv...and screw it in with your hands in your tv.....when you have your VCR on the direct tv wont show and if your direct tv is on when your xbox and VCR are on it still wont so turn off the VCR to get direct tv back again.....im 13 and i figured this out...hopefully this helps a bit
Sep 26, 2009 | Microsoft Xbox 360 Console
Diamond Multimedia ( VC500) Video Capture After I installed the program files from the disc and set up all the three cables for the audio and video, everything is hooked on right and tight but once I plug...
I was having this problem also. I originally plugged my 3 video cables into the VCR outlets in the front of the vcr. I finally turned the vcr around and found two other sets of video out plugs. One was to a dvd/dvr and the other was a vcr out. I took the plugs from the front of the vcr and plugged it into the dvd/dvr out and it worked! Good luck with your problem. Hope the resolution is just as simple.
Mar 16, 2009 | Diamond Multimedia ( VC500) Video Capture
Have cable tv and wanting to tape a certain channel
I would suggest that you disconnect the VCR from any signal source. UNPLUG the VCR from the power source [a/c] for at least one hour, more if possible. Before you are ready to plug the machine into a/c attach an antenna to the antenna INPUT, the VCR output goes to input of tv. [ DON'T attach cable box, or any such machine to the input of VCR.] Plug vcr into outlet and turn ON. Place TV-VCR switch on TV. [no remote control??] Change the channel MANUALLY, one channel at a time. If you see tv stations as you change the channel [KEEP changing until you have reached the " end of the line " of broadcast channels.] then you are good.Connecting the vcr to a cable box[ANY KIND!] you can only RECORD through the vcr what you watch on cable.
Dec 09, 2008 | Sanyo VWM-900 VHS VCR
Hook up
On the back, there are three ports that are color-coded and match the cables. Take the yellow cable and plug it into the yellow port. Do the same with the red and white. Take the other end of the cables and plug them into your TV or VCR. Most TVs and VCRs have ports for the cables on either the back or front, and are also color-coded. Plug the yellow cable into the yellow plug on your TV/VCR, and repeat for the red and white cables.
Oct 24, 2008 | Philips Magnavox MWD7006 DVD Player
Can't Get Any TV picture on mySharp 27DV-S100 TV-VCR-DVD combo
open back up the set and look closly at all of the plug connections and cables as you might not have pulled one out all the way but may have in inadvertantly pulled on a cable of one of them and pulled one out have way or just a little. My freind it happens to the professionals all the time. Make sure you check all the plugs on the VCR as well as the tv that they are instraight and flush. Good Luck Ps Please dont forget to rate this.
Oct 15, 2006 | Sharp 27DV-S100 27 in. TV/VCR/DVD Combo
JVC HR-A592U S-VHS VCR Logo
120 people viewed this question
Top JVC Televison & Video Experts
Todd Hill
Todd Hill
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
