Facebook Social Network Logo
Anonymous Posted on Oct 21, 2009
I cannot access my old facebook account after another one was created using the same email address. I have not received any responses to my email requests to fix this problem.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 02, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
170
Points
Want to go back to my old facebook account Esther mukonyo and delete the new one essy njahira.
Anonymous
Level 1:
  • Contributor 28 Answers
  • Posted on Oct 23, 2009
Anonymous
Contributor
Level 1:
Answers
28
Questions
0
Helped
5619
Points
61
well this is quite simple your old account has been deleted. You cant make multiple accounts with the same email in facebook!!
We have one email account and I have just set up a facebook profile but now we can't access my husbands account
You can not have more than one facebook account. facebook doesn't allow that. I'm guessing you used one email address to create each account and the last one you created is the one that works. Well there is a way around this; get another email address for your husband. Use a different browser than the one you used to create your account. Have him create a facebook account with the new email address using the different browser. Then from then on you each use the browser you created your each accounts with. If you don't, eventually facebook will think you're the same person having two account and lock one of them down.
I am all having a problem with the Facebook Mobile site. When I log on and try to click on anything I keep getting the message to Confirm email & to enter Confirmation Code. Bert frustrating.
Hi. I had a similar problem... it can be fixed! Email facebook and explain what happened. Be patient and persistent.
send email to:
[email protected]
the first email I received back from them (day after I emailed) was generic saying:
"Our records indicate that there is not a disabled account associated with the address you are writing from. If you are referring to another account that has been disabled, please contact us directly from the email address you use to log in to that account..."
Except the email I was using DID belong to my missing account. So I replied with the SAME original message. And detailed what happened to my account.
I received a SECOND response, identical to the first.
I emailed them AGAIN detailing what happened.
FINALLY (about 1 1/2 weeks later) I received this email:
"Hi Chelsey,
Your original account has been reactivated and you should be able to access it now. Sorry for the inconvenience. If you have any further questions, please visit our Help Center at the following address:
http://www.facebook.com/help.php
Thanks for contacting Facebook,
Lo
4helpful
How can I make sure I don’t lose access to my account?
In the event that you forget your password, you will need to request a password reset. This password reset email will only go to email addresses that you have confirmed on your account. As such, if you are unable to access the email addresses on your Facebook account, you will not be able to receive your password reset email and may lose access to your account completely. You can prevent this situation by taking the following measures:
  • Add a secondary email address to your Facebook account.
  • Add a security question to your Facebook account.
  • Make sure email addresses on your Facebook account are active (you are able to access them).
  • Maintain accurate information on your profile, such as name, date of birth, and email addresses. This helps us locate your account, should you lose access to it.
1helpful
I cannot receive the security code to verify my Facebook account.
switch to yahoo mail account maybe hotmail have problem recieving email..or pop block outgoing email
When you do a seach on my name I see an old Facebook account. I don't know the e-mail address it was created under. Is there anyway to find out what the e-mail address was for this old account?
The best solution will be to email facebook support and ask them to email the account (assuming you still have access to your old email accounts). Otherwise you will need to prove that it is your account. Whatever you do you will need to message facebook support.
The help page for forgotten email accounts is
http://www.facebook.com/help/login.php
but you might also want to look at
http://www.facebook.com/help/?page=749
1helpful
Im having trouble logging into facebook. For about 2 weeks now, when I try to login it tells me I have the wrong username/password combination. When I try to reset my password it tells me that my email...
I can’t receive the email to reset my password, because I no longer have access to the email address associated with my account. You can change your login email address at any time in the Settings ta... You can change your login email address at any time in the Settings tab of the Account page. Please note that you can log in with any email address you have added to your account. However, if you no longer have access to an email address associated with your Facebook account, you will need to contact your email service provider in order to regain access to that address.
If you forgot your password or would like it reset, click here to reset your password.
If you’re still unable to log in or change your login email address, click here.
If you are having trouble accessing an existing account on the site, please do not create another account, as this is a violation of our Terms of Use and may delay resolution of the issue.
12helpful
3answers
Someone used my facebook email to create another account
which account you can't access?Is is the Facebook or Msn account? If you can access your msn account, you need to change your password immediately and use your email to access the Facebook account. Now, if you can't access your msn account, click on 'Forgot your password' and restore it by anwering questions (your question you saved when you first did this account)
4helpful
My email was used to confirm another account,my facebook gone now
send email to:
[email protected]
"Hi Chelsey,
Lo
User Operations
Facebook"
IT CAN BE RESTORED!!!! :) [email protected]
Top Facebook Computers & Internet Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Kolbrun...
Are you a Facebook Computer and Internet Expert? Answer questions, earn points and help others
