Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ge profile artica ice dispenser and chute frosing.
Ge profile artica ice dispenser and chute frosting. Makes ice and dispenses. Blades frost and chute frosts, then clogs from frost and blades have trouble dispensing when frosting.
  • Anonymous Oct 21, 2009
    I checked out the chute opening today, it is closing, maybe other times it is not. If it is closing, what might be the cause of the frost inside on the blades and dispenser opening to the chute.
  • First Choice Appliance
    First Choice Appliance May 11, 2010
    Is sounds like you have air leak through the ice chute. Problem could be in ice buildup, broken or misplaced part in the chute opening mechanism.
John Tripp
  • GE Master
  • 4,656 Answers
This may be because the chute door is not all the way shut when off. If yes the warm moist air is being pulled through the opening and causing this. Sea Breeze
Posted on Oct 21, 2009
Testimonial: "new here--did not mean to rate you low..sorry!"
  • 2 more comments
  • John Tripp
    John Tripp Oct 21, 2009
    I don't understand why you would rate me so poorly and I was here to help. I really do not understand. The PSS26MSRSS is easy for me to help solve this problem.
  • John Tripp
    John Tripp Oct 23, 2009
    Thank You. I understand. If your freezer is sealed this should not be a problem. The freezer is one of the best dehumidifiers around if draining and defrosting properly. So moisture above the amount that is removed by defrost would only linger if the defrost condensate drain has a blockage or water or moisture is entering from any location. Ice would get smaller in the ice bin when defrosting correctly. Then if you know moisture is not entering then we need to find out why it's not leaving. I will get back soon with you but I need you to have a look below the refrigerator to see if the defrost has been going to the pan under the refrigerator every 8 to 10 hours, Sea Breeze
  • John Tripp
    Until I hear from you I am going to assume that defrost is happening on the normal routine of about every 10 hours for your Profile. So even if this information does not seem to fit it may be useful at a later date. Here is some web pages that I am working on and have been collecting material from different places. Sea Breeze Tips has a little information on the top of the page and from there I want you to click on to HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER which does not sound appropriate but it has a short You Tube movie that simplifies what I am trying to say. The bottom of that page is only if your refrigerator is a repeat offender in the area of drain freeze over. And here is a Profile ARTICA Service Manual that will come in handy later. I know it does not list the 26 cu ft. model but it does and will be very helpful if you have a control board fail or a fan failure. PROFILE ARTICA SERVICE MANUAL CLICK HERE When you have had time to look over this material let me know and anything that you notice or I missed. Thanks, Sea Breeze
  • John Tripp
    John Tripp Oct 24, 2009
    Like to know if the problem has been located and resolved or if you would like to continue with my assistance contact => Sea Breeze just above the Fixya Tech Support Box on right. Or try http://seabreeze.fixya.com that is having problems because of server overload. [email protected]
Anonymous
    New Friend:
I have just solved my own ice dispencer frost problem.
1. The control pannel has to be removed. Look up under the pannel and you will see 3 small holes were the snaps lock in. Press a small screw driver in to the right most hole as you pry outward with a 2nd small screw driver. Unplug the control pannel.
2. Now you will see 4 screws, remove them and pull that segmant out.
3. Remove the 2 screws that hold the flapper in place.
4. Remove the 3 screws holding the solenoid in place.
5. Check the solenoid plunger for rust. If it is rusty, sand it down, clean it and the bore and spray paint the plunger. I use a 12 minute enamel and sped up the drying prosses with a hair dryer then cooled it in the freezer when no longer tacky. Apply a small amount of Pam to the piston and bore. Also Pam the pivot ends of the flapper arm and at the point were the pivot arm engages the solenoid.
You may have encountered a lot of mold as I did in complete shock. Use bleach wipes and dissasemble the flapper all the way for cleaning. It breaks down from the pivot arm and the rubber disc and foam back come appart also. When you have cleaned to your satisfaction, reassemble all small parts and replace in reverse order. Then remove the frost and the blockage were the ice comes from the tray and you should be all set.
Posted on Oct 24, 2009
Frost forms on the inside opening of the chute for the water/ice dispenser. Also frost on the exit chute from the ice cube tray. The frost is present a day or so after I clean it off.
The door flap which releases the ice , on the door , is not closing completely .Usually this is caused by a rusted plunger so both the solenoid and plunger will have to be replaced , These parts are located behind the dispenser board so be sure to remove the top freezer door hinge cover and unplug the plug there , to remove all power going to the door , before attempting this repair . I think the part number is WR62X10055 for the kit .
When it doesn't close , it lets warm air into the freezer and causes frost on the dispenser AND on the ice bin outlet . Also , using 10 glasses or more , of crushed ice a day can cause this .
Aug 19, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Ice sticing in ice dispenser chute
only use ice from the ice maker, some frost is normal, but , lower temp in freezer
May 19, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frost buildup inside freezer door at ice dispenser
you are still not getting a seal on that flap. It sounds as if it may be warped. THe reason the frost and ice is building up is due to the flap not sealing there isn't any other reson for your problem. Good luck on your repairs
Dave
Oct 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice chute cloggs with solid chunk of ice over time
Have you had high humidity over the last few months where you live?
This could be normal under those conditions.
BUT.....make sure the door is closing FULLY at the ice dispenser outlet.
Aug 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My ice dispenser in my GE Artica is clogged. There is frost and ice on the dispenser and at the top of the chute. What is the problem?
The dispensor flap is not closing . Usually the flap solenoid rusts causing non closure . When not closing , warm air is sucked in by the fan , causing frost . Without model number , cant give you the part number you need . Solenoid and plunger is the part name .
Aug 09, 2009 | GE Profile Arctica Stainless Steel Top...
GE profile Artica side by side. I am getting a frost build up
Sounds like the dispensor flap is not closing completely , pulling outside air in . Using a flashlight on the outside of the flap , look inside to see if any light is visible . If so , then the ice flap plunger and solenoid will have to be replaced . Also , excessive crushed ice can also cause frosting .
Jul 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile 26.6 cu. ft. side by side is frosting in the shoot
Oddly enough, the problem is with your ice dispenser. What happens is that the door at the bottom of the ice chute is probably not sealed. This is likely because there is a solenoid that is supposed to hold that door open when you push your cup against the dispenser arm, and THEN, close it again when you release. If the chute door is not sealed, warmer, moist air from outside the refridgerator will be canstantly drawn up the chute where the moisture will freeze as frost. Gradually, this frost builds up in the chute until there is no longer enough room foir the ice to fall. You can usually look up at the chute from outside and see that the door is not sealed. In my case, I left it unsealed because the door would not open to let the ice out. It took me about 3 months to figure out that this was causing my frost-clogging problem. The solution is to replace the solenoid that is supposed to open and close the chuite door. If you remove the despenser panel, you will see that this solenoid is probably all rusted up and not working. The following link will allow you to enter you model number and see a diagram of the offending area. http://www.pcappliancerepair.com/model-display.php
Jun 10, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Sep 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
734 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Ron Beer
Ron Beer
Level 1 Expert
geob91
