SOURCE: Mode for playback of older 8mm tapes using Sony DCR-TRV730 ?
In 1990s Sony camcorder records movie in analog format so playing in digital camcorder like DCR-TRV730 doesn't mean it will be converted in digital format and you can not import file in PC for editing purpose. You will get analog signal while playing back old cassettes.
Regarding SP, LP speed, its decided at time of recording. Camera sens SP or LP automatically in playback and set itself accordingly.
If you want to convert old cassettes into digital format, connect our camcorder to DVD recorder and burn DVD which is digital format, copy DVD files in to PC and do desired editing.
SOURCE: Need to set DVD recorder process to SLP instead of SP.
Press the REC MODE button until slp shows up in the bottom right side of the tv.
SOURCE: Need Manual for RCA VHS Camcorder Model No. CC 285
TRY THIS .GOOGLE Manual for RCA VHS Camcorder Model No. CC 285
MAY NEED A BIT OF SEARHING
IF YOU FIND A PDF VERSION,DOWNLOAD IT,AND BURN TO DISC
KEEP IT SAFE RUN IT ON COMPUTER OR PRINT IT OFF
We perhaps could have been of use, when you had told us in the first place what brand and model your recorder is. For the VCR part, some recorders do have a setting in the menu, to switch to LP (long play) but not all records have this option. So when the manual does not offer this option, your recorder can't.
When you post the details of your recorder, perhaps I manage to find the specs and will be able to tell you what your recorder can and can't. Give me a day, because it is bed time for me.
