Question about Bosch 24 in. PIE675T01E Electric Cooktop
Wolf cooktop 5HR light keeps turning on. Pressing
Wolf cooktop 5HR light keeps turning on. Pressing clear will turn off the light temporarily, but the light turns back on. Other than that the cooktop works fine.
Posted by keckgeorge on
  • Anonymous Mar 19, 2014
    Hi, we've purchased a 2nd hand induction cooktop, which was working before, but now it's not. The lights turn on and it starts to heat up, but then turns itself off after 7 or so seconds.
Anonymous
    New Friend:
Turn off power to the cooktop (i.e., using circuit breaker if needed) for 15-20 minutes. Once turned power back on, problem disappeared for me. The semiconductor needed to be reset
Posted on Jan 03, 2010
  • vicelise2 Jun 02, 2011
    The appliance is locked in "Showroom" mode. Easy fix. Simply put on "Lock" then hold the "Melt" for about 5-7 seconds. This will unlock the showroom mode. Got this from Wolf tech support and it solved the problem. I think it happened when I locked to clean my cooktop. Must have depressed the melt key and set it to this disply mode.
ERROR BL IS COMING UP WHY IS THIS?
If Shr (5hr) appears on the display then the cooktop is in showroom mode. To exit showroom mode the cooktop must be locked by pressing and holding the key symbol for 5 seconds. After the cooktop is locked, press and hold the melt touch pad for 5 seconds.
Jan 04, 2016 | Cooktops
How do I unlock my Dacor cooktop
When your Dacor cooktop is locked, there will be a red light lit above the Dacor emblem located under your cooktop controls.
If you see this light, pressing the Dacor emblem for three seconds will turn it off and unlock your range. Pressing it again for three seconds will again lock your range and turn the light back on.
Another fun thing about that Dacor emblem is that if one or more of your elements are lit, tapping it twice in quick succession will turn off all elements.
Sep 04, 2011 | Dacor Millennia ETT304 Electric Cooktop
We can't turn off the igniter on our gas cook top
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Mar 27, 2011 | Wolf Range RHP-6-36 12 in. Gas Cooktop
I have a Wolf gourmet 30" stove. it's about 10
Interesting, I'm looking for a solution to a similar issue. Our new (7 month old) 30'' Wolf Range has this issue. When both front burners are light, the back burner's electronic starter begins to click, but only when you put a pan on the front left burner. I believe the iron/steel in the pan is causing a magnetic field thats starting the rear burner to go off.. just don't know.. will report back after the repair person comes.
Jan 22, 2011 | Wolf Range 18 in. SPR-100 Gas Cooktop
Wolf Induction cooktop is locked in Showroom mode
May 01, 2010 | LG 30" Built-In Electric Induction Cooktop...
Wolf electric cooktop
This is what Sub-Zero has to say (sounds like techno-gibberish)
Looks like it's technician time -
CT Induction Cooktop Error Code E13
Jan 04, 2018 | Cooktops
The printed readout lights read set 8888 set 8888 but no touch buttens work
wolf electric cooktop... several seconds after turning a burner on the unit goes to lock mode
Oct 30, 2008 | Cooktops
Wolf Oven
Use DeBruce Polish for the stainless steel and smooth cook tops. We get DeBruce at debrucepolish.com
Aug 07, 2008 | Wolf Range 18 in. SPR-100 Gas Cooktop
Cooktop shut off and lock itself up
36" electric wolf brand cooktop. Goes off completely after just few seconds sometimes 30 sec. sometimes minute..Repair man looked at it-thinks either something electrical or some sensor messed up.He took apart look at electric ribbon nothing looked over puts back together..turns on and it goes completely blank again..no error codes..any suggestions
Feb 22, 2008 | Cooktops
Wolf range cooktop
I just installed a Wolf gas cooktop and had the same problem in that all 4 burners would light just fine but the electronic igniters would not stop clicking on all four. What I found was that the electrical outlet that my gas cooktop was plugged into had the polarity reversed. I tested the outlet with a polarity testing module (you can get one at Home Depot and it checks polarity, grounding, GFI and is handy to have around, small and inexpensive). I plugged it in and the lights told me that the polarity was reversed. I reversed the wires in the outlet (exchanged the white and black wires) put the cover back on, plugged in the cook top and now it works like a champ! no more constant clicking. By the way, we had a cooktop before this one with electronic ignition and never had a problem, apparently it didn't care about the polarity.
Nov 10, 2007 | Wolf Range 18 in. SPR-100 Gas Cooktop
Bosch 24 in. PIE675T01E Electric Cooktop Logo
1,332 people viewed this question
Top Bosch Cooktops Experts
Paul Carew
mpservices
Are you a Bosch Cooktop Expert? Answer questions, earn points and help others
