Canon Sure Shot 80U 35mm Point and Shoot Camera Logo
Posted on Oct 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Letter 'H' keeps appering in teh window. i remove battery and return and it clears. i have replaced battery but still it is intermittent. Some photos are dull and hazy. is it damp? LIght?
MIke
Level 2:
  • Expert 685 Answers
  • Posted on Nov 24, 2009
MIke
Expert
Level 2:
Answers
685
Questions
0
Helped
224626
Points
895
The camera is on its last legs and is going to fail sometime soon. It may be time for a new camera.
Ford airbag code 54
94+ AIR BAG DIAGNOSTIC TROUBLE CODES/CLEARING
Code Component/Fault Description
No Air Bag Indicator - Inoperative Indicator Circuit
Continuous Air Bag Indicator - Diagnostic Trouble Code Timed Out, Diagnostic Monitor Disconnected or Inoperative, or No Ignition Voltage to Diagnostic Monitor.
12 Lost Battery Feed
13 Air Bag Circuit Shorted to Ground
14 Primary Crash Sensor Circuit Shorted to Ground
21 Diagnostic Monitor Not Mounted to Vehicle Properly
22 Safing Sensor Output Circuit Shorted to Battery Voltage
23 Memory Clear Circuit Improperly Grounded
24 System Disarm Failure or Internal Diagnostic Monitor Fault
32 Driver Side Air Bag Circuit High Resistance or Open
33 Passenger Side Air Bag Circuit High Resistance or Open
34 Driver Side Air Bag Circuit Low Resistance or Shorted
35 Passenger Side Air Bag Circuit Low Resistance or Shorted
41 RH Radiator Primary Crash Sensor Feed/Return Circuit Open
42 LH Radiator Primary Crash Sensor Feed/Return Circuit Open
44 RH Radiator Primary Crash Sensor Not Mounted to Vehicle Properly
45 LH Radiator Primary Crash Sensor Not Mounted to Vehicle Properly
52 Intermittent or Repaired Lost Battery Feed
53 Intermittent or Repaired Air Bag Circuit Shorted to Ground
54 Intermittent or Repaired Primary Crash Sensor Circuit Shorted to Ground
61 Intermittent or Repaired Diagnostic Monitor Not Mounted to Vehicle Properly
62 Intermittent or Repaired Safing Sensor Output Circuit Shorted to Battery Voltage
63 Intermittent or Repaired Memory Clear Circuit Improperly Grounded
64 Intermittent or Repaired System Disarm Failure or Internal Diagnostic Monitor Fault
72 Intermittent or Repaired Driver Side Air Bag Circuit High Resistance or Open
73 Intermittent or Repaired Passenger Side Air Bag Circuit High Resistance or Open
74 Intermittent or Repaired Driver Side Air Bag Circuit Low Resistance or Shorted
75 Intermittent or Repaired Passenger Side Air Bag Circuit Low Resistance or Shorted
81 Intermittent or Repaired RH Radiator Primary Crash Sensor Feed/Return Circuit Open
82 Intermittent or Repaired LH Radiator Primary Crash Sensor Feed/Return Circuit Open
84 Intermittent or Repaired RH Radiator Primary Crash Sensor Not Mounted to Vehicle
85 Intermittent or Repaired LH Radiator Primary Crash Sensor Not Mounted to Vehicle
Rapid Continuous Flashing of Air Bag Indicator (No Diagnostic Trouble Code) Both Primary Crash Sensors Disconnected Assembly Plant Mode
TROUBLE CODE CLEARING
1. Follow the diagnostic procedures to service the fault condition flashing on the air bag indicator prior to code clearing.
2. Cycle the ignition switch to OFF and then to RUN.
3. Observe air bag indicator prove-out (six ? two seconds) followed by diagnostic trouble code (52-85) flashing completely one time.
4. Locate the Diagnostic "Trouble Code Clear" Connector (grey connector). located underneath the glove compartment, left side (06010) containing Circuits 631 (T/R) and 57 (BK).
5. Use a jumper wire to short Circuit 631 (T/R) to Circuit 57 (BK) or to another good ground. This short must be made after the diagnostic trouble code flashes completely one time, but before the warning light stays on continuously.
6. Hold short until air bag diagnostic monitor tone sounds (approximately five seconds).
7. Release short on Circuit 631 (T/R) to Circuit 57 (BK). This short must be released within 25 seconds after the diagnostic monitor tone sounds.
Diagnostic trouble code is now cleared from memory. Next highest priority diagnostic trouble code stored (if one exists) will begin flashing.
The codes and clearing proceedure above are to be used as a guide, NO claims are implied as to the correctness or accuracy of either.
Fail please inset disk into removable disk Insert your pen drive on your usb port... 1.Right Click "My Computer" 2. Select Manage 3. Click Disk Management 4. Look for the Removable...
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
example on how to safe photo's or data to a usb drive
click start all programs accessories open windows explorer navigate to your photos
right click on the photo's select copy navigate back to the usb drive right click select paste or select the top photo hold the mouse cursor then select the bottom photo then drag the photos to your usb drive then drop them
or if you are downloading photos from the internet
once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into a folder in my documents or another device or a usb device
if you need more help with this post a reply
hope this helps
Transcend StoreJet 320GB can't access to my Pc. When it plugged to Usb port, there is no flash and cannot be access by autorun just like before. I can see my Storejet device in Ejection system of...
restart the computer with teh drive plugged in and let windows run a disk-check on the drive the autorun file me just need tobe replaced and windows will do this on startup. If it doesn't then go to start, run, type CMD and hit return, then type in the disk drive letter (ie E:\) then hit enter, nest type chkdsk /r/f hit enter, if it asks to unmount the drive hit y and enter this should force windows to repair the drive. This may take several hours so be prepared to let your computer run for that length of time.
Setup is locked, hoekan ik het unlocken om een verse window xp te installeren
OK ..you have several options ...First ..try to open it up ..and remove the bios battery from the main board..remember to also remove any other power source ..and place the battery back after 30 seconds..This will clear the bios settings and also the password..
If this will not work , you can try to fool the system by inserting the disk ..and start without the hard disk on ..It will take teh next option and will boot from the disk ..and you have to plug the hard disk on immediately ..It may work ..
If the password will be removed by removing battery ..than all you have to do is press f12 for boot menu and start from the disk and install .
Another way is to start windows installation from teh previous windows ..Just open the disk and click set-up ..or install windows..it will start from windows and after loading primary files will restart and continue normal ..
the last option is to remove the hard disk and install a clean operation system in another computer and place it back ..
it will work just fine ..but you will need all drivers for your computer to be installed manually and will also need to be made from a boot-able disk ..and not from recovery ..
Anyway ..try the battery removal and let me know what goes on ..and after that we'll see ..
please try to use English ..even if it is not very good...I will try to understand..
Battery light on console is intermittent
Sounds like the alternator is going faulty. There is a brush inside the alternator that wears over time. If you are capable, you can remove the battery, remove the wires from teh alternator, loosen and remove the dive belt, and remove the alternator. Take it to an auto electrician to be rebuilt, or buy a replacement and fit back in.
Apperantly the battery went dead. How can I
you will need a number 5 torx screwdriver, remove the 4 screws in the back of the unit and then remove the back cover wich is now hold only by clips, be careful because the battery is glued to the back cover that give accsess to the battery! also you can check out this tutorial on youtube on how to take appart the TX!
A/c, wiper + intermittant (rear) recirc neons are
It sounds like the battery was not disconected long enough to fully reset the computer.
Loosen and remove the neg. battery terminal, wait about 20min and replace the terminal. Things should
return to normal. Hope this helps. Good luck
Pen drive not showing in my explorer.
Its a common problem with the pendrive, in windows. some time it doesnot detect or not showing clearly that device. you have to check your pendrive manufacturer and driver details. and also check it out driver signing.
Do you have mapped network drives on your computer? If you have this may cause your problem. When you insert the PEN Drive into USB and the "safely remove hardware" icon appers try to right-click on it and choose "eject" or "remove" (don't remember :), then pull the PEN DRIVE from the USB and connect it again. Go to Windows Explorer and try to open all your mapped drives, then the content of your PEN DRIVE must be loaded into your Windows Explorer. This is happened sometimes, because PEN DRIVE try to assign the first free drive letter after your phisical drive letters, and if you have a mapped drive letter, the PEN DRIVE assign one of them.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
