Question about Nortel Norstar 16-Line PBX Speakerphone
Problem with power supply in PBX o KSU
I have a telephone system Nortel Norstar CICS but the internal power supply is not working
Posted by jczertuche on
dan4261
    Problem Solver:
  • 14 Answers
Power supplies come with the main chassis. You may need to have the chassis replaced. are you sure it is receiving power ok? You can replace the cards and the flash card into the new chassis and restore programming.
Posted on Oct 22, 2009
When I press memory buttons on one particular telephone in our office they all dial reception. How do I fix this?
PDF]Telephone Features Programming Guide - Avaya Support
https://downloads.avaya.com/css/P8/documents/100142941 AvayaNORTEL NETWORKS is a trademark of Nortel Networks. ... All other trademarks and registered trademarks are the property of their ... One-line and two-line displays . ...Memory buttons . ... Call anomalies for telephones without line buttons . .... Select how you dial your calls . ... Receive a busy signal on an internal call .
Norstar How to program phone how to program voice mail ...
www.phonserv.com/1_PDF_user_guide_meridian_norstar_phone_syste...
Nortel Networks Meridian Norstar How to program voice mail phone feature codes ...Modular ICS KSU must be programmed with an M7310 or a M7324 telephone. ... Lift handset, press Voice Call key or press the Feature button, then press 66 2. .... At the LOG: prompt, enter your mailbox#(extension #. and your password all ...
[PDF]N QRTEL NORSTAR
Jan 18, 2016 | NorStar M7324 Telephone
Power source
A Nortel Key Service Unit, an ICS (MICS,CICS), BCM (50,100 etc), Norstar (308,616,824), an Avaya IP Office running Nortel cards, or there is another company that makes a Nortel emulation key system but I can't recall what it is right now.
Carl
Nov 23, 2012 | NorStar Meridian M7310 Phone
Alarm: 51-2 - no dialtone-cannot dial out or receive calls
On of your trunk modules went bad.
In this case -2 is the trunks on the KSU, check all connections reboot phone system to see if issue clears.
Aug 06, 2012 | Nortel Norstar 16-Line PBX Speakerphone
Can you use the nortel t7316e on a normal land-line..? I've noticed if I plug it in to a land-line that the top left red light flickers on and off, along with the microphone button bottom left and the...
You get around the problem by unpluging the phone and taking it back to wherever you got it, or going out and buying a CICS, MICS, or BCM cabinet to plug the phone into.
A Multi-line digital phone doesn't operate on a POTS telephone line.
Carl
May 28, 2011 | NorStar T7316E Corded Phone
What module do I need to purchase to get called ID on my M7310
The Norstar 616 system was made before CLID was readily available. You could however, purchase a Nortel CICS system with CLID card(s). CI trunk cards handle up to 4 lines per card making the capacity of the system 8 lines by 16 stations.The CICS system will work with the existing m7310 sets you have so you wouldn't have to incur the cost of new telephones.
Jul 13, 2010 | NorStar Meridian M7310 Phone
I am having trouble activating a new extension on our system. Nortel T7316E.
Are Your socket wired correctly? Pins 3 & 4 on the Socket UK Spec...
Have you tried another Telephone in that Socket for the new extension?...
Are the 'Cursors' Flashing on the phone when pluging in?
Jun 30, 2010 | Nortel Norstar 16-Line PBX Speakerphone
We have lost power a couple times this week and our system had reset, losing our third line and voicemail greeting will not prompt when suppose to. We still have out greeting, it is just not picking up.
What type of System is it? Norstar systems default to 2 lines if they loose memory (which isn't supposed to happen). That being said, I recently had had to replace an old Norstar 616 that would not hold memory after a power outage. I took the KSU apart and could not find any internal battery to replace. I'm guessing some kind of capacitor ?? In any case the system had to be replaced. Bill C. www.dyna-tech.us We also do remote programming on Norstar CICS ans MICS.
Mar 26, 2010 | NorStar M7310 Corded Phone
''nortel meridian switch goes dead then resets'' power supply?
Sorry to tell you but your system is going dead the power supply is going bad . The system needs to be replaced. if you are local in so cal I can install a replacement system for you 626-712-5753 efren
Feb 04, 2009 | Nortel Norstar 16-Line PBX Speakerphone
T7316e Nortel Meridian Norstar Telephone
Feature *1, Press the desired key, dial the #
Nov 03, 2008 | Nortel Norstar 16-Line PBX Speakerphone
Nortel Norstar 16-Line PBX Speakerphone Logo
179 people viewed this question
Top Nortel Lands Phones Experts
Marvin
Marvin
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
