Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Tv stays on for about 3 minutes the shuts off
Posted by sherrynstan on
Shahid Electronics
  • 10,594 Answers
If it is Mitsubishi WD-52525 DLP TV then it sounds weak lamp problem in TV and TV needs lamp replacement.
How old is this TV and did you replaced lamp recently?
Lamp replacement is written in user manual of TV and it is easy work.
Please buy Mitsubishi original lamp for TV safety.
Thanks.
Posted on Oct 21, 2009
Audio shuts off after 2 minutes, no sound
It's probably Thermal Runaway' a term used when a electronic component over heats and quits working. Go to Radio Shack and buy a can of freeze spray, Take it down to where you can get to the chassis and when it goes out starting spraying components and when you get the right one the sound will pop back on/ This spray is not flammable and does not conduct electricty. That component will have to be replaced,
Mar 12, 2014 | Samsung 65" Series 7 LED HDTV - UN65F7100
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
TV comes on, but shuts off after 3 minutes. I must wait at least 5 minutes to get it to turn back on again. TV will ONLY stay on if DVD drawer is OPEN!
dvd is overheating its circuit. Keep the tray open to dry up condensation. then leave TV on standby to keep moisture out.
Dec 07, 2010 | Toshiba MD13N3 13 in. TV/DVD Combo
I have Toshiba TV Model #65HM167. The problem is when I turn it on - it will stay on for 30m to 3 hrs, and then just shut it self down. I pull the power cord for 30 minutes and then plug it back in and it...
check the fan to make is working properly. It's in the lamp compartment on the left side of the unit. clean the vent on the rear unit and the fan fin's gently. good luck
Dec 13, 2009 | Toshiba 50HM66 52" Television
I have a rca tv that is about 4 years old it not a flat screen it will not stay on you can turn ot on it stays 3 to 4 minutes and then shuts off
On your Deflection Board its the Bottom board to the left CK 3 capacitors cp150 2200uf 16v if it is puffed up on top it is Bad other 2 are cp114,cp120 220uf 35v
Dec 03, 2009 | RCA R52WH73 Projection Television
Sylvania 6419TC
My Sylvania T.V. turns on and then it turns off by itself. It only stays on for onr minute.
Aug 10, 2008 | Sylvania 6419TC 19" TV
Shutting off and on...
the problem may be due to dry soldering in the power supply stage if it was with the lamp there would be red or green light showing the presence of the power to the tv after making it own some of the components get hot and it will make the the soldering point conectionless and after some time the heat sink get cooled and the soldering point gets connected and u will see the picture again it is a simple problem if u have a soldering iron u make it hot and re solder all the components in the first part of the circuit board and the problem if rectified
Jul 03, 2007 | LG RU52SZ30 52" Television
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
312 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
