Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
My TI-84 Plus Silver edition will not turn on. I have tried new batteries and everything, but it just does not turn on. Is there a way to reset it or something although the calculator does not turn on?
Posted by ovilla05 on
k24674
  • Texas Instru... Master
  • 8,091 Answers
Here it is from the horse's mouth (TI Knowledge base)
For the TI-83 Plus Family, TI-84 Plus Family:
Caution: The resets described in these troubleshooting steps will cause a lossof applications, programs and data. If at all possible please create a backup using TI Connect™ first.
  1. Try a new set of AAA batteries.
  2. Adjustthe contrast by pressing and releasing the [2nd] key followed bypressing and releasing the up arrow; repeat as necessary. To adjust orlighten the display, use the down arrow.
  3. Remove one of theAAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR],reinsert the AAA battery and then turn the calculator on. Thecalculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  4. Removeone of the AAA batteries. Press and hold the [DEL] key. While holding[DEL], reinsert the AAA battery and then turn the calculator on. Thecalculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI83-family or Ti84 Plus family to reinstall the calculator operating system (see below.)
  5. Removeall of the batteries including the round lithium battery for 5 minutes.After the 5 minute period, reinsert all of the batteries and turn thecalculator on. Adjust the contrast if necessary.
Reinstalling the OS fot the TI84Plus
How do I correct the Error Waiting...Please Install Calculator SoftwareNow message on my TI-83 Plus family or TI-84 Plus family calculator?
If an operating system (OS) update fails or is interrupted, the calculator will be in an inoperable state with the message Waiting...Please install calculator software now.The most common cause of a transfer being interrupted is updating theoperating system on a calculator with low batteries. Users will need touse the TI Connectivity cable and the TI Connect software to send theoperating system to the calculator. Make sure to have the latestversion of TI Connect installed on the computer.
In order to install the software please follow these steps:
1. Connect the TI Connectivity cable between the computer and the calculator.
2. Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
3. Follow the on-screen directions to reinstall the calculator's OS.
Ifthe message "Error! Press any key to turn unit off. Then turn unit backon." appears on the graphing calculator, quickly, remove one batteryfrom the calculator and reinstall it while the transfer is taking place.
Hope it helps.
Posted on Oct 21, 2009
  • beccagrib
    beccagrib Oct 03, 2012
    Thank you sooo much! I was thought my calculator was broken! I replaced the batteries and it would flash on for two seconds and turn off again. I was freaking out! Your directions worked perfectly on the first attempt! THANK YOU!!
None of the buttons on my TI-84 Plus Silver Edition will work
Does it turn on with a cursor, Have you tried a fresh set (all four) of batteries, Is there any corrosion/dirt on the battery contacts and the I/O port that you can see, Have you tried any resets?
Jun 09, 2014 | Texas Instruments TI-84 Plus Silver...
Ti-84 plus c silver edition will not turn on
Try reinstalling the OS, that might resolve the problem.
Jan 23, 2014 | Texas Instruments TI-84 Plus Silver...
Hi, i was wondering if you can help me with my ti-84 plus silver edition calculator. The problem is that it simply won't turn on, even with NEW batteries. Thank you
1. Check the battery holding area and make sure that all of the connectors are protruding enouugh for the batteries to make a good connection.
2. Check the diagram for exact polarity placement.
3. If still no power, try using you electrical plug for power. The problem could be with a connector and you may have to purchase a new TI.
Nov 16, 2010 | Texas Instruments TI-84 Plus Silver...
My ti 84 plus silver edition wont turn on. I
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
If that doesn't work, add a comment to this post and we'll go from there.
May 31, 2010 | Texas Instruments TI-84 Plus Silver...
TI-84 Plus Silver Edition not responding!
what helped for me is leaving it w/h any battery's (no backup battery either) for a few days. Now miraculously it works!
May 06, 2010 | Texas Instruments TI-84 Plus Silver...
My TI-84 Plus Silver Edition got wet and now the
I would suggest putting it in some dry rice. That will soak up all the moisture. You might also try drying it with a hair dryer.
Mar 10, 2010 | Texas Instruments TI-84 Plus Calculator
TI-84 Plus Silver Edition turns off immediately, all batteries have been replaced, but unit still turns off. I even replaced the memory battery.
You may need to reset calculator. Take ou the batteries and the backup battery. Leave them out for about 8 hours. Then put everything back in. Hopefully this will work.
May 21, 2009 | Texas Instruments TI-84 Plus Silver...
Blank screen with new batteries! TI-84 Silver Plus
ON, 2nd, [up] arrow to change the contrast. Works 99% of the time....
Oct 19, 2008 | Texas Instruments TI-84 Plus Silver...
Won't stay on.
have you tried manually resetting like the manual suggests? Take out the AAA's only, hold the ON button for 10 seconds and then re-install the batteries and turn it on. If that doesn't work, I have no other suggestions.
Apr 07, 2008 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
1,796 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Paul Bade
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
