I have a sonic wall TZ170 and I am trying to configure a VPN connection however I seem to be having a problem the configuration page continues saying error on page.
6
Select the tab that corresponds to the type of VPN network you are trying to connect to. You can select "L2TP," "PPTP" and "IPSec."
7
Enter a description of the VPN" in the "Description" field. Enter the IP address of the VPN in the "Server" field and enter your VPN user name in the "Account" field. If you use a password to access the VPN, enter your case-sensitive password in the "Password" field.
8
Tap the "Save" button located in the upper right corner to save your VPN settings.
9
Move the switch located to the right of "VPN" to the "On" position. Your iPod will automatically connect to the VPN network.
Please find below is to configure what ever you want.
Setup Wizard - This wizard will help you quickly configure the SonicWALL to secure your Internet connection. Once completed, you can use the SonicWALL Web Management Interface for additional configuration.
Registration & License Wizard - This wizard will help you register you and your firewall with mysonicwall.com and obtain licenses for additional Security Services features.
PortShield Interface Wizard - Segment and configure the integrated managed LAN switch of the SonicWALL.
Public Server Wizard - Quickly configure your SonicWALL to provide public access to an internal server.
VPN Wizard - Create a new site-to-site VPN Policy or configure the WAN GroupVPN to accept connections from the SonicWALL Global VPN Client
Thanks
- Logon to the configuration page of your D-Link. - Go to Advanced tab - And Click on Firewall Settings on the left side - Under that look for Application Gateway Level at the bottom and you must uncheck at the box on it and click on save settings at the top.
Need more info, " I want to configure two VPN for different customers but both at the same host computer." You can havemultiple VPN`s, and port forward to anyewhere on the inside or dmz.
Need to know what you are trying to achieve. madmac
Hi Rajmeet,
Here is the documentation on the SOnicwall TZ170 the detail configuration can be found on page 211. Please let me know if this helps you and if youhave any other questions.
http://www.sonicwall.com/downloads/SonicWALL_SonicOS_Standard_3.1_Administrators_Guide.pdf
