Uninstall any existing Kodak EasyShare software. Google around for Kodak EasyShare software and include the model of your camera in the search. You may have downloaded a later or earlier version of the software that doesn't support your camera.
Kodak EasyShare software is just a photo-viewing software which isn't really necessary in case you don't know.
This problem is frequently due to corroded battery terminals inside the
camera. Remove the batteries and wipe the terminals with a soft cloth
(heavy corrosion may require a fine wire brush, steel wool, or
sandpaper). Remove any residue left in the camera by the cleaning.
Clean the terminals on the batteries in the same manner, and then
replace them in the camera. This cures most problems, but if it
doesn't work for you, check the Kodak troubleshooting guide at:
Make sure batteries are NEW! Even half-way dead batteries will have negative actions on camera. Also if you have a memory card, try removing it and see if your camera act normal now. Some memory cards have different impact on digital cameras. Kodak will fix any camera for $40.
Remove the batteries and clean the battery contacts inside the camera
with a soft cloth (a heavy buildup on the contacts may require cleaning
with a fine wire brush, steel wool, or sandpaper). Remove any residue
that the cleaning leaves in the camera, and then reinstall the
batteries. This clears most power-on problems, but if yours persists,
