I want 2 know what the speed sensor does and what does it affect when it goes bad? does it have an affect on the automatic transmission?
TX BOB
If a speed sensor goes bad your ABS system will not function meaning your anti-locking brakes system, will not pulsate mulitple times if you step on the brake too hard or you hit a patch of ice, Most people hit the brakes hard when they start to slide across the road, however that allows the car to slide even more because the brakes are completely locked. The Speed sensor monitors the wheel and once it determines that the car is sliding it then kicks in and presses and releases the brake very fast and that is while you press the brake once.
To be more specific it's speed sensor A
reverse gear comes and goes,
