ICOM Informatique M700Pro (150 Channels) 2-Way Radio Logo
Posted on Oct 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an Icom-M700 pro, serial number2404380 installed on my yacht. I entered in set mode and probably did something wrong because since that moment the radio only transmit in AM and FSK mode. I am now in Tonga and plan to sail to New Zealand next week, I really need to transmit in USB mode, and I will appreciate if someone can explain to me what I need to do to reset the radio in the way it was before? Thanks a lot, best regards
Anonymous
Level 3:
Brigadier General:
  • Master 5,158 Answers
  • Posted on Oct 21, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
5158
Questions
5
Helped
2066146
Points
15105
Under some circumstances the transceiver’s internal
CPU may cause erroneous indications on the display.
If this happens, reset the CPU as follows:
While pushing [ENT] + [0], push [POWER] to turn
power on.
• The CPU is reset and the display at right appears.
CAUTION: Resetting the CPU returns set mode
contents to their default values.
that's the quickest way to do it, hopefully you don't have alot of stored frequecies in memory.
you can get a pdf copy of the manual here
http://www.icomamerica.com/en/products/marine/ssb/m700pro/default.aspx
robert
Need Icom IC-41Pro programming software.
Icom IC-41PRO User Programming Software
Radiotronics Pty Ltd https://www.radiotronics.com.au > ... > Software
Icom CS-41PRO is the genuine and official programming software for the Icom IC-41PRO UHF CB two-way radio. Compatible with Windows 10, 8.1, 7, Vista and XP.
Free · ‎In stock
ICOM CS-41PRO v1.02 Dealer Programming/Alignment ...
Radio Cables https://radiocables.com.au > cs41pro-software
ICOM Dealer Programming, (includes Alignment built-in) Software CS-410PRO Revision 1.02 - Instantly available for Download! Locating service & storage fee, ...
A$24.99
Icom CS-41Pro CPS (R1.02) Programming Software
HamFiles https://hamfiles.co.uk > icom-cs41-pro
Jun 25, 2017 - Programming software for: IC-41Pro. Includes: Installation & Connection Instructions. 35rem Notes: TX (Editing is restricted) ...
ICOM CS-41Pro Rev. 1.02 PROGRAMMING &amp
eBay https://www.ebay.com > itm
The CS-41 Pro (Dealer) is designed for clone and programming the ICOM IC-41 Pro. ICOM CS-41Pro (dealer) Rev 1.02. Clone and Programming Software.
US$24.49
Icom Programming Software Guide
Quality Two-Way Radios https://quality2wayradios.com > store > icom-program...
Icom Programming Software Guide. The guide below outlines by Radio M
How to repair Icom IC-M700 HF transeiver?
Does it have an external speaker plugged in the back? If so try unplugging it see if the internal speaker works, if it doesnt have an external speaker plugged in try one, maybe the internal speaker went bad from moisture.
How to Fix Icom IC-M700 HF Transeiver?
This is a marine radio and is subject to corrosion on the speaker jack and other connectors. You may also have a blown internal speaker. Try plugging in an external speaker and see if you have any noise coming through. If not, it may just be the jack, but the re is a possibility that the audio amplifier has burnt out.
1helpful
Ihave an old icom icm- 55 marine radio what ariel do i need and do i need to swr the ariel will a cb ariel work basically what do i need to do to get it working
All marine VHF radios must be licensed. A marine radio station must also have a call-sign allocated to the vessel it is installed in. Shore based stations can also be licensed but only where they are involved in marine based activities e.g Yacht Clubs, Marinas, Harbour Masters, Rescue Services etc.
In the UK ships radio licences can be obtained from Ofcom. They are free for non-commercial users.
The user must also have a Marine VHF Radio operators certificate. This requires taking an exam. In the UK contact the Royal Yachting Association for a copy of the syllabus and local examiners.
More information about the licensing rules, courses and exams can be found here. http://www.rya.org.uk/infoadvice/regssafety/Pages/licensingelec.aspx
The ICOM ICM55 is a good radio set and can still be used in an existing (marine) installation but it does not meet the standards for new installations as it does not have DSC (digital selective calling) capabilities - which all new fixed sets must now have. It is therefore very unlikely that you will be able to get a licence to install one.
To get it working you will need a proper marine band VHF aerial which operates in the frequency range 156-MHz. They usually come with cable attached but if a longer cable is needed, or the aerial is not cabled in the first place, use flexible 75 ohm co-axial cable with a copper core and braid/foil screen. Use proper aerial connectors (type F or BC are most commonly used and can be obtained from most good electronic component suppliers more cheaply than from a boat chandlers. Do not use push-fit TV aerial plugs)
Citizens Band radio works on the much lower frequency MHz band and therefore a CB aerial will not work with a marine VHF radio set. Please see this Wikipedia article for more information http://en.wikipedia.org/wiki/Marine_VHF_radio
I bought a new logic unit (front face) of Icom F121 and it needs to be restored. How do you restore a logic unit for the Icom F121?
1- You have to to "Reserve" mode.2- Change Set Mode Access: Inhibit to Enable3- Common>>Secutity Change Set Mode Access : Inhibit to Enable4- Enter RX TX frequency and write to the radio.
or you can download version Rev 1.7 from here:
http://www.two-way-radio-tools.com/icom-softwares.html
http://www.two-way-radio-tools.com/icom-radio.html
I HAVE A PRODUCT KEY DONT WORK
it has to work, microsoft never make mistakes.
youre probably using the wrong version of office or else typing it the wrong way or the serial is fake.
I want to delete everything and start over!
you'll need to go to SAFE mode, or boot from the install disk, which ever is most accessible.
http://tinyurl.com/6qcpgy
Code 10 error over my network adapter in device manager
You need to download and install the proper drivers from Compaq (now HP). Go to http://www.compaq.com and do the following:
Click "Get Support" at the top.
Enter "armada m700" in the "Enter a product number" box.
Click the little submit button that looks like ">>".
Click "Download drivers and software".
Click one of the "Windows XP" links. Doesn't matter which one.
Scroll down and click the "Download" buttons that correspond to each driver you want to download.
Install the drivers you downloaded.
Top ICOM Informatique Radio Communications Experts
eradiostore
eradiostore
Larry Ng
Larry Ng
Jim
Level 1 Expert
Are you an ICOM Informatique Radio Communication Expert? Answer questions, earn points and help others
