Garden Logo
Posted on Oct 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I bought a surplus ryobi 20cc grasscutter.it starts for a while and sundenly stops.carbs good,new sparkplugs.and found out that current from the ignition coil doesnt flow how can i fix this problem,,
Anonymous
Level 2:
New Friend:
  • Expert 169 Answers
  • Posted on Nov 20, 2009
Anonymous
Expert
Level 2:
New Friend:
Answers
169
Questions
0
Helped
81321
Points
393
U have diagnosed this to the ign coil. To make sure its the coil unplug the kill wire and see if spark is present. If not bad coil good luck!
1helpful
2answers
Ryobi RBV26B 26cc Petrol Blower wont start - Help !
It sounds like you've done a long list of troubleshooting activities. At this time, it might be good to call Ryobi and ask them for a local dealer that can provide a free in-person analysis of your machine in order to get it to start again.
Thank you.
2answers
I have replaced spark plug, gasolines w/fuel filter, and carburetor but ryobi s430 still won't start.
Make sure that all of your fuel lines are good with no leaks and cracks. Ditto for primer bulb. If all ok, then you need to clean out carb, or get a kit for it.
Gets fire and gas wont start
Be careful with primerbulb especially if use alkylat fuel for a fuel surplus some times remove the sparkplug and holding the mufler in down to the ground position so to release the surplus out of the machine , if that is not working after replace sparkplug and starting , then you can have a problem with compression but first the spark of your machine must be colored white/blue and not red. if thats also good then remove the muffler and look on the exhaustside of your piston if there are grooves on then you know whats wrong in the fastest time if that is not that it looks smooth like a mirror then seals on the crankshaft , tankairiation good ? gasket(s)carburetor and cilinder underside .
Feb 08, 2016 • Garden
2answers
It is new and will not fire up
take it back for a warranty service check
is the stop switch been activated
Kill swich stopped working ,now won't start
May be your compression is lost if its cold ? remove the muffler and look at your piston if thats smooth like a mirror then look your sparkplug maybe a sparkplug gem ??
Or a primerbulb to much used a surplus?
Nov 13, 2015 • Garden
5helpful
Bought new e3 plugs for weedeaters and cant find gaps for them i have a Featherlite 20cc Fl20 and a Ryobi 31cc 700R
The gap for the Weed Eater 20cc engine can be set @ .025". The larger engine Ryobi 31cc/32cc class can be set @ .030" Either engine would operate within that .005" range and I know a 32cc Poulan calls for a .030" gap.
Jul 09, 2010 • Garden
10helpful
RYOBI weed eater.hard to start. starts then stops
I have a ryobi doule line bought in 1997..Had same problem put new gas cap on and problem solved..could not get air in....
I found this power blower, i had it running for a week or 2. i saw that the primer bulb has been weathered i bought the bulb and it has not started.
check compresstion first if good.then check for fire if good then spray little startfluide in carb if ti starts rebuild carb if it dont start you have problem in blower some where like fire sparkplug timing on flywheel key take flywheel off check key.make sure kill switch wire is not shorting out somewhere.make sure magnet on flywheel is good.let me know if this helps you ok
Jul 24, 2009 • Garden
Top Ryobi Garden Experts
Jay Finke
Jay Finke
john h
Steve Sweetleaf
Steve Sweetleaf
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
