Try holding the code key and pressing the "L". If that dosen't do it remove the batteries turn it off wait a minite and restart this will put everything at default setting and clear the memory. If you still have the problem Press code "L" hold down the "L" type 001 to set the keyboard to U.S. If this works you need a keyboard for a permanent repair. For a keyboard contact Geo. Beyers Co. @ 800-392-8085.
When the RH side of the keboard types numbers instead of letters then the Num Lock (number lock) key has been pressed. Press the Num Lock Key again to return to letters again, usually this is usually done by pressing the Shift key plus the ScrLk (Scroll lock) key, this key will be also marked NumLk, and there will be a LED light that will indicate when the number lock is on.
You need to press the NUM Lock key.
The NUM lock key is usually the same key as the ScrLk key but to select the NUM lock you need to press and hold down the Shift key and then press the NumLk/ScrLk key. A LED light will light up to indicate the number keypad is on.
Is it giving you numbers and symbols?
do this:
Press and hold the function key fn while pressing the num lock key num lk .
This will deactivate the integrated keyboard/numeric keypad, and the keys will respond normally.
Please remember to rate all users who assist you for free :)
