Power button lock out
Monitor will not turn off, POWER BUTTON LOCK OUT keeps coming on
  • 328 Answers
Sounds like an HP monitor. Press and hold the power button for about 30 seconds while the monitor is on until it shuts off.
-=/ MLF /=-
Posted on Oct 21, 2009
  • Brian Ellis
    Brian Ellis Oct 04, 2011
    Thank you /MLF/ I was having the powerlockout problem, your solution fixed it. 10/4/2011
View sonicva1931wma-led monitor power button locked?
Posted on Jul 23, 2012
answer dude
SOURCE: monitor power button is lock how to unlock it
if it says power button locked hold "<" button and power button till the message goes.(at least a min)
Posted on Dec 05, 2010
I can't unlock my osd screen, tried everything
While holding it, turn the monitor on. Once the monitor is on for a few seconds, let go of the "left" button. Your OSD should be unlocked. This is how it works to lock press and hold the MENU button while the monitor is off and then press power button to turn themonitor on.
How to unlock the OSD of an AOC monitor - Quora
https://www.quora.com/How-do-you-unlock-the-OSD-of-an-AOC-monitor Feedback
About this result
How to unlock OSD my HPx20 LED wide screen monitor?.. - HP Support ...
https://h30434.www3.hp.com/...Lockup/...unlock-OSD-my...screen-monitor/.../74766... Jul 4, 2011 - Turn off the monitor, press down the Menu button and then turn on the monitor. Wait 10-20 seconds. This should unlock the OSD. "Power button is locked" message - HP Monitor 27es
Aug. 31, 2017
OSD Lockout on HP Pavilion 27xi - how to unlock?
Apr. 5, 2017
HP monitor Main Menu / OSD Lockout cycle continuously
Jul. 9, 2009
More results from h30434.www3.hp.com
HP LCD and LED Monitors - OSD Lockout Message Appears on the ...
https://support.hp.com/ca-en/document/c01932183 What to do when an OSD Lock out message opens. ... OSD lockout prevents the OSD menu from opening on the screen when a button is accidentally pressed.
display - How do I lock and unlock the OSD of a "AOC monitor 21 ...
https://superuser.com/.../how-do-i-lock-and-unlock-the-osd-of-a-aoc-monitor-21 Aug 29, 2009 - OSD Lock Function: To lock the OSD-First make the Monitor off by pressing power button and then hold the Left button for 5 seconds and simultaneously hit the power button with the left button and the osd is Locked. If your AOC e2343F is locked then just power off your screen and hold power and menu buttons together.
can unlock my osd screen Google Search
Jun 12, 2018 | Cars & Trucks
My AOC LED screen with touch front panal OSD has been locked... how to unlock it
OSD Lock Function: To lock the OSD, press and hold the MENUbutton while the monitor is off and then press power button to turn the monitor on. To un-lock the OSD - press and hold the MENUbutton while the monitor is off and then press power button to turn the monitor on.
Sep 25, 2013 | Computers & Internet
Power button lock icon keeps popping up on screen. tried to push reuird buttons to fix. buttons on monitor are not working properly.
Push and hold your monitor's POWER button until the monitor shuts off completely.
After it is shut off, press the POWER button again to turn it back on and the lock should be disabled.
Sep 04, 2011 | ViewSonic Va2431wm LCD Monitor
What is combination for entering service menu on LG M1962D?
1. Power off your monitor with POWER button
- Hold MENU button and keep it pressed while pressing POWER button
2. Press MENU button to enter Service menu
3. Change panel type
- Press SET button until PANEL text is yellow and press (-) two times to change it to LPL22W 4L
- Press MENU button to close the Service menu
- Press POWER button to power off your monitor and remove power cable for a minute and plug it in again
Jan 18, 2011 | LG M1962D Monitor
The brightness icon stays on my screen
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
May need to do this with if off (OSD Lock Function: To lock the OSD, press and hold the MENU button while the monitor is off and then press power button to turn the monitor on. To un-lock the OSD - press and hold the MENU button while the monitor is off and then press power button to turn the monitor on.)
Oct 31, 2010 | Office Equipment & Supplies
What is osd locked
You can try the following, to lock or unlock OSD function: To lock the OSD, press and hold the MENU button while the monitor is off and then press power button to turn the monitor on. To un-lock the OSD - press and hold the MENU button while the monitor is off and then press power button to turn the monitor on. Hope this is helpful
Jul 22, 2010 | HP vs19 (Silver) 19" LCD Monitor
Osd locked shows after trying to adjust the volume
To lock or unlock OSD on your Monitor do the following1. Turn off the monitor2. Hold the Menu Button3. Turn on the power by pressing the power button of your monitorNote: make sure you keep the Mouse button pressed while turning on the monitorFor any further assistance please feel free to revert with comments.
Thank you for choosing Fixya
Apr 16, 2010 | HP w17e Monitor
OSD LOCK
Normally the OSD lock will only be displayed for 5 seconds.
Regardless you should be able to get rid of it by pressing holding the up arrow key for 10 seconds.
If this fails to resolve the issue try this. Disconnect power cord. Now press and hold button 1. Plug the power cord back in. You may have to press the power button while still holding button 1. The OSD lock should clear after that.
Hope this helps.
Oct 02, 2009 | ViewSonic E70f 17" CRT Monitor
OSD locked how do I unlock
OSD Lock Function: To lock the OSD, press and hold the Left button while the monitor is off and then press power button to turn the monitor on. To un-lock the OSD - press and hold the Left button while the monitor is off and then press power button to turn the monitor on.
Sep 11, 2009 | AOC 917Sw 19" LCD Monitor
OSD Lock
  • OSD Lock Function: To lock the OSD, press and hold the Left button while the monitor is off and then press power button to turn the monitor on. To un-lock the OSD - press and hold the Left button while the monitor is off and then press power button to turn the monitor on.
Apr 18, 2008 | AOC LM729 17" LCD Monitor
Computers & Internet Logo
7,478 people viewed this question
Ekse
Marvin
Marvin
