You have to make sure that your Cartridges is clean. Try to vacum of blow both of the cartridge hole and also the place where you put the cartridge, Sometime very small tiny dirt will makes that the cartridge cannot be recognise by the console.
Instead of 1 starter game and a few demo game that you get from Leapfrog
Connect, you can also get more downloadable games for your Leapster 2.
You can get it here: leapster-2.blogspot.com
if the light goes green for a very short period before going red again
it means theres a short on the circuit board. u can try and find the
problem but because the circuitry is very small, it wont be easy to
find. only other solution is to buy a new circuit board :(
Ensure NO GAME is in unit
Power Unit off
While turning Leapster 2 on, hold down HINT KEY. (Key in middle with question mark on left hand side)
Once unit switches to other menu, Hit A to begin calibrating.
Follow prompts with Sylas pen to reprogram Stylus pen.
Once you are done it will return to original Calibrating Menu.
Power Unit off Turn unit on with game inserted. Stylus pen should respond.
1) Ensure that a cartridge is not inserted
2) Hold
down the Hint (?) button while turning the unit on. Continue to hold the
Hint button down until the LEAPSTER menu appears.
3) When the LEAPSTER menu screen appears, press the A button
4) Touch each of the crosshairs that appear with the stylus
5) Restart unit
Do comment if it helped or not in any manner ill know.
How did you try recaibrating? I just fixed my son's Leapster 2 a few minutes ago. I read a couple different recalibration instructions and the one that works for the Leapster 2 is:
1-Hold down the (?) Hint button while turning on the system.
2-Keep holding it down until the Leapster menu shows up
3-Let it go and press the A button
4-Touch each crosshairs x with the pen tip
5-When it goes back to the menu screen, restart the unit
We have 3 Leapsters. The old green model and 2 newer models. Our green one started doing that not long after having it. But it still works and if it shuts off, then we just turn it back on again. When I called up c/s for Leapster, they sort of make it difficult to return. And then I was not promised a new one, but it could be new or refurbished. I let it go. Now w/ the 2 new models, I believe this has happened. I've questioned if my kid's are accidentally hitting the power button. I have seen the green one power off before. I purchased the $10 plug in's. So worth it. No more batteries. And we haven't had any issues. So perhaps it is the batteries. Call up Leapster though and see what they have to say. Good luck! :)
1) Ensure that a cartridge is not inserted 2) Hold down the Hint button while turning the unit on 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
Hold the hint button (question mark) when turning on the device. When the device turns on, do the stylus calibration and touch each of the crosshairs that shows up. After you are finished restart the leapster and you should be fine.
Had the same problem. I could randomly make it turn on by some bazzarre combination of pushing buttons. Now won't do anything. Call Leapster 800 #, and thought I was getting a bunch of b.s. from a "tech" person, however IT IMMEDIATELY RESOLVED THIS PROBLEM. Remove the battery pack and batteries. Take a pencil eraser and rub/clean the contact point where each battery goes in on the tray (except the coil sides). Reinstall the batt's back in the trey. Use the eraser to do the same thing to the outside contact points on the outside edge of the tray as well as on the Leapster itself where the tray goes. Finally reinstall the the battery tray, and BINGO ! Crazy....I would have lost a bet on this "fix".
