Remove the clamps from the suction nozzle and pull out the roller. First of all check that both ball bearings are in order, so dust and hair free and run easily without too much play. Look carefully at the different depth marks on both sides and Make sure that they are reverted to the same setting marker.The belt is in the middle and with the square gray dial in front of the suction nozzle, you fully tighten the string so that the red color face of the top is visible when you look through the hole of the suction nozzle you see that the belt is tightened and in this Position may leave the belt for a short period of time, as always as soon as possible, ensure that the tension of the belt is off after each use.In short, in the tightened position, place the suction nozzle on the mounting bell at the bottom by lifting the motor housing slightly at the front or adjusting the depth adjustment as much as possible, just what you want, first place the suction nozzle on it and fix it with the clamp and then Couterclockwise turn the gray knob into the green mode. Kirby Heritage II and Legend Vacuum Owner Video
the brush bar has 3 settings marked on the end of the plastic clips that hold the bar in place make sure it is set to no 2 both ends,lay machine down and start roll should spin also check bar is free to move by hand
You can purchase a wide variety of high quality Kirby replacement parts for your Kirby vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Generic problem for all Vacuums How do you use and How do you use and what attachments for upholstery cleaning with the Heritage II I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Kirby has a spin brush that is round on the newer Kirby’s and it works on the suction from the vacuum and it fits on the end of the vacuum hose but it does not fit into corners very well or your can take some Kirby shampoo in the spray water bottle and use a kitchen scrub brush for the corners. Other wise you can use the actually Kirby Shampooer of which is very hard and unfriendly; the spin brush would be my selection. You can check with your local vacuum cleaner dealer in your area and also in the yellow pages. Also you can call the Kirby factory to see if they can direct you. The Kirby factory is listed below: http://kirby.comContact Us by Phone United States and Canada 1-800-494-8586 Between the hours of 8:00 am to 5:00 pm EST Monday thru Friday
Here is a online guide....it's for the G series Kirbys. They're similar enough that it should help. Pay special attention to the belt lifting process...it's exactly the same as for the Heritage II, and it's also where I think your problem lies. I have a Heritage II manual available too! Hope I have helped...
Marci
