This works for my DCP-7020, so it may work on the 7040.
If your drum is still good - take it out and put it back in - the trick is to LEAVE THE FRONT DOOR OPEN after you put it back in. With the door still OPEN push the "options" button and you will be prompted for "New Drum?" and then push the "Up" button for 'Yes' and "Accepted" will appear on the lcd screen - and then the drum counter will be reset.
DCP-7040 Reset "Drum End Soon" message: After you put your new drum into the machine, DO NOT close the cover immediately. First, press the Clear/Back button and follow the instructions to reset the drum. Then you may close the door.
Yes! this right. It worked for me. Thanx
mine was different, pushed option button but it did not work. pusehd up arrow and it did
Worked for me as well, thank you.
Yes, had the same problem, and this is the correct solution. How many of these machines are thrown away because they are made to stop functioning, even when they are not broken?
There is a missing step here that might confuse people.
1. Open front cover
2. Pull out the drum and toner casing
3. Wait 1-2 minutes and insert the drum and toner casing back into the printer (LEAVE THE COVER OPEN)
4. "The missing step" Press Clear/Back Button to clear the message "Close the front panel"
5. New Drum? - Yes (Up arrow)
6. Accepted? - Close the front panel.
Yes this works for the 7040.
