Question about Carrier 38CKC042 Air Conditioner
Carrier 1.5 tons ac Indoor unit switch off and write on display screen ( E5 ) please help me to solve the problem
Posted by kemo1990 on
Anonymous
    Problem Solver:
  • 10 Answers
If you have the manual the codes are listed in there. if you lost the manual, you can download a copy at Carrier.com
Posted on Oct 21, 2009
My 1 ton carrier split ac 15 minits running after stop and blinking green light 4 times.whats the problem ?
This problem is outdoor unit issue. Blinking 4 times in carrier highwall unit means Compressor drive malfunction. Possible cause are the following:- Stuck up or grounded compressor.- Magnetic contractor in outdoor unit is defective or indoor unit relay supplying outdoor unit is defective.- No power supply going to outdoor unit
Sep 22, 2018 | Carrier Heating & Cooling
Electrolux split ac shown e5 error how to resolve this error
Protection against AC overcurrent E5
"Switch the appliance off and on again. If this does not resolve the issue, contact an Authorised Service Centre."
Free service manual for an Electrolux appliance.
https://www.manualslib.com/manual/824502/Electrolux-Exh09hl1w.html?page=31
Electrolux EXH09HL1W Service Manual Error Codes
Quoting from a service manual:
https://www.manualslib.com/manual/824502/Electrolux-Exh09hl1w.html?page=46#manual
"(6) Over current protection
E5 is displayed on indoor unit
Yellow LED lamp of outdoor unit blinks for 5 times
#It indicates that the current of the complete unit is too large. Check if voltage of power supply is normal."
Electrolux EXH09HL1W Service Manual Page 46
Aug 21, 2018 | Electrolux Heating & Cooling
My tcl split ac works for 5 min, then gives e5 code.
E5 s a communication error between the indoor and outdoor units. It is stated in the service manual that the wiring between the indoor and outdoor has probably separated at one end of the terminal block. Most of the time however, it is usually a failure of either the indoor or outdoor electronic boards. A multimeter and knowledge of how to read "communications voltages is required. The machine will continually assess itself electronically to make sure all components are working properly. If after a given amount of attempts to communicate with the outdoor unit the machine still cant "talk" to the other 1/2 , it will show an E5 error and shut itself down. You could try switching off the power at the isolator or meter box for at LEAST 15 minutes and then turn back on to see if it resets. This sometimes works. Do not, just switch off and switch straight back on again.
Mar 24, 2015 | Heating & Cooling
I have samsung split ac 1.5 ton 2.5 years old when am switch on the ac the indoor unit is working when it tires to on the out door unit after 3 minute delay suddenly the ac is restarting but the out d
Make sure all of the pressure switches are closed on the low voltage control circuit on the outdoor unit. If any are stuck open, the compressor will not kick on. Or just push the compressor contactor in with an insulated screwdriver to ensure the compressor does actually work.
Dec 28, 2014 | Samsung Heating & Cooling
My onida split ac shows F6 . What can I do?
onida 1 ton split ac F6 earror how problem retified
Mar 10, 2012 | Heating & Cooling
I live in Phoenix, AZ. I have a 2 story 2300 sq ft home built in 2001. I have two Carrier AC units outside on the side of the house. They are the originals. The Large unit (upstairs) model 38CKC042340 and...
T the upstairs is a 3 1/2 ton 10.0 SEER condenser, and the downstairs is a 2 1/2 ton 10.0 SEER condenser. You can use any 10 SEER Unit on replacement, but if you go any higher in SEER (efficiency), there is a possibility the unit will freeze up. The reason is because the indoor coil also has an efficiency rating (10.0 SEER). It is not a good idea to mismatch units when it comes to SEER. Otherwise, you can use any brand of unit, if you want to go higher in efficiency, you need to change the indoor coil as well. Hope this helps. Mark
Jul 31, 2011 | Heating & Cooling
Hi there I have a model number for my carrier a/c unit. I need to find out the tonnage. 38ykc042300 Please any help I will be very greatful.
This is a 3 and 1/2 ton unit.
The 042 in the model number is the tonnage of your carrier unit.
AC tonnage is based on 12,000 btu per ton.
12,000.....1 ton
18,000.....1 and 1/2 ton
24,000.....2 ton
30,000.....2 and 1/2 ton
36,000.....3 ton
42,000.....3 and 1/2 ton
48,000.....4 ton
60,000.....5 ton.
There is no 4 and 1/2 ton unit.
Apr 09, 2011 | Heating & Cooling
Carrier Programmable Thermostat - E5 Code
Ok what you need to do is call your local service company and have a technician come out and check your Thermostat, its currently not able to read humidity probably due to a power surge
Apr 28, 2009 | Carrier Heating & Cooling
Carrier 38CKC042 Air Conditioner Logo
385 people viewed this question
Top Carrier Heating & Cooling Experts
Dennis Boxerman
shizznat
Level 1 Expert
jdthefixer
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
