Take a look at this image, read the Had drive manual on how to set the jumper, Try cable select jumper settings, if not work, try the master settings, if not try the slave settings, one of the settings must go on and works fine.
Here where you can find the jumper settings,
Try this option, if it will work then BIOS compatibility problem,
Partition your hardrive into 80GB and use only the 80 GB in installing the operating system. If it works then you need to update the BIOS firmware of your laptop.
Try this option, if it will not work then BIOS compatibility problem,
You need to change the boot order in the bios menu.
Device 1 should be the optical drive, drive 2 should be the HDD. When you are running again, remember to change order back. Good Luck
Yes the cd/dvd drive is set to boot from. It works when I use the original hard drive which is 40 GB Seagate eide Momentus.
I did have the cdrom/dvd set as the first boot device and it still doesn't do anything.
I think it might be a power problem. My old drive only uses .42 amp where as the new drive uses .55 amp.
DO YOU HAVE "BOOT FROM CD/DVD DRIVE" CHECKED IN THE BIOS?
