SOURCE: Casio Exilim EX-Z70 lens error
yes I can help you lens zoom motor is out or the gears are stripped. goto www.digitalcamrepair.com for more help.
SOURCE: CASIO EXILIM EX-Z70 BATTERY CHARGER IS FLASHING RED AND NOT CHARGING THE BATTERY
it wud flash red until it gets fully loaded..its normal...try charging for 90 mintutes..as that is when it is completely charged
Happy to help
HAve a nice day!
tc
SOURCE: we have a casio exilim
Does the lens actually extend? If it does try and give it a little twist in both directions while you're pulling on it, but don't do it too hard or it will break. You should feel a slight click. If that doesn't fix it you may have to disassemble the camera, or take it to a service place.
SOURCE: A friend dropped my camera
the repairing cost depends on the condition, the actual damage. And important is where you live. Because in some countries the labour is too high to fix the camera.
SOURCE: My pictures turn out fuzzy
Flash should turn on by pressing the "Set" button and then the down arrow until you get to the flash menu. Choose the setting that looks like a lightning bolt.
If that doesn't work press the "Menu" button and then press the "right arrow" until you are on the far right tab. Press the "up arrow" until you come to "Reset." Press the "Right arrow." The camera will ask you if you want to reset it. Tell it "Yes." This will take it back to factory settings and clear any mode that turns the flash off.
Are the pictures fuzzy because the flash isn't working? Are outdoor pictures in daylight fuzzy or OK? If they are fuzzy all the time you may have a lens problem. If they are only fuzzy when the flash is needed, fixing your flash should cure the problem.
