Question about Whirlpool Microwave Ovens
Wont work When I plug in my whirlpool wall mounted microwave it asks to set the time. I try and by the second number it quits. Sometimes it turns on a fan and wont respond to anything but a swift pull of the plug my numbers for the microwave are mhg 150 x h9-1 1- 2002
Posted by jtnemesis on
Teddy Bear
    Problem Solver:
  • 5 Answers
Don't know this particular model, but it sounds like you are just pressing the time buttons for cooking and not actually setting the time clock which is what it's asking for. Are you following the instructions for setting time as detailed in your instruction book?
Posted on Oct 20, 2009
My whirlpool combo wall oven microwave RMC305PVS01 wont work. The lcd panel says door and there is no light inside the microwave. Do I pull the microwave change bulb and door switch??
I would start with the switch. Might be an adjustment. Microwaves usually have 2 or 3 door switches mounted to an assenbly. Sometimes these need adjusted. Still need to take control panel off to adjust.
Oct 07, 2015 | Whirlpool Microwave Ovens
Electrolux wall mount micro wave oven combo doesn't work
Good Morning Friend,
I understand that your Electrolux wall mount microwave oven combo is not working. I see that the oven is working, but the microwave is not. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try any setting. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. If further troubleshooting is needed, please provide me with the model number of your air conditioner. Hope this is helpful.
-Best Regards-
WP
Jul 06, 2014 | Electrolux EI30MH55GS Microwave Oven
Whirlpool Roper Microwave MHE14XMB turntable stops turning
Hello :
The turntable has a separate motor under the unit(inside) that is quite small..... They just do go out from time to time..!!!!! Just remember to set the timer for shorter periods of time on items that require long cook times and turn it around the other way . Repairing is a bit expensive . You can ask first .
good luck .
please rate .
Mar 30, 2010 | Whirlpool MH7140XF Microwave Oven
Remove a whirlpool over the range microwave oven
Jim here. In cabinet above microwave, locate 2 mounting bolts.
Place a box on the stove top to support the microwave once the mounting bolts are removed (you may wish to cover the box with a thick towel or small throw rug).
Procedure:
1. Unplug microwave.
2. Remove both mounting bolts from top of microwave (they secure it to the overhead cabinet).
3. With microwave front angled down onto box, pull some of power cord out of hole (to provide some moving space).
4. With microwave hand supported, remove box from stove top (a second set of hands would be helpful here).
5. HARD PART- detach top of microwave back from wall mounting plate by placing a hand under the bottom rear of the microwave and pushing up. (Wall mounting plate is screwed into the wall behind the microwave and provides both top and bottom support to the back of the microwave.)
6. Lower front of microwave until you can see about a 1-inch clearance between the top-rear of the microwave and the cabinet above it.
7. Firmly lift the microwave straight up and then bring forward. It should be free of the wall mounting plate.
Sep 30, 2009 | Maytag MMV4205 Microwave Oven
Wall mounting needed for a top mount microwave/hood combination Whirlpool Model MH2175SB1. The cabinet above the stove is too flimsy to support the heavy microwave (50-60 pounds). Called Whirlpool. Sent me...
Is there a wall behind where the microwave is to fit?
Most of these ship with a mounting plate and instructions for mounting to the wall. In fact, the wall bracket carries about 1/2 the weight, and the overhead cabinets carry the other half. The plates come with a good set of instructions for how to install.
Whirlpool is sending you to a distributor because they have to watch liability in this litigous world we live in..
Jan 29, 2009 | Whirlpool Microwave Ovens
Microwave wont heat
The manual says "while in standby mode, press and hold the '3' key on the keypad for 3 seconds until 2 tones sound and the 'DEMO' icon appears. Repeat to turn demo mode off."
You can download a copy of the manual here:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208206572.pdf
Jan 13, 2009 | Whirlpool MH7140XF Microwave Oven
Hi Just received new Whirlpool Max 25 microwave. It all checked out fine first of all - I set the clock and the timer ok and tested by heating a mug of water and it worked fine. I unplugged it to move it...
It sounds like there may be a misaligned door switch mount or door hinge.
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer again to get it fixed free.
You will have to contact Whirlpool again. You can call the number in the manual or visit the Web site they might give their.
I would ask for their nearest authorized service center.
Sep 03, 2008 | Whirlpool Microwave Ovens
Brand new.......clicking noise, will only run 2 seconds
Since it's new, I would let Whirlpool cover the repairs.
You can contact their customer service at http://www.whirlpool.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 17, 2008 | Whirlpool MH1170XS Microwave Oven
Microwave problem
I would first suspect a bad door switch or door switch mount.
If you follow up with your full model number, I can possibly give more precise advice.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Aug 29, 2007 | Kenmore 64663 Microwave Oven
Microwave Ovens Logo
Top Whirlpool Microwave Ovens Experts
Michael Thomas
Michael Thomas
Gerry Harvey
Gerry Harvey
Sheldon Dedek
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
