Question about Ohm O2 OW-15 15" Subwoofer, Dual 4 Voice Coil, Steel Basket Car Speaker
I got a 15' Targa 800w rms dvc sud car. Driving it 3000w targa mono block mono fully mosfet. When i put it say 1 quater volume theres a knocking sound on the sub how do i solve this
Posted by sterkwees62 on
Anonymous
    Scholar:
  • 125 Answers
Hi, this might help you:
i can point it out exactly but i think it's some electronic parts inside that are damaged... in that case i hope it can be repaired, if not....
I hope this is useful, and greets.
Posted on Oct 20, 2009
How to wire a 12inch 4ohm dvc sub to 2ohm
Take two wires, equal length. Reach from positive of 1 coil and hook too positive of 2nd coil, now do the same with negative, neg to neg.. Then pos of sub to amp. And neg of sub too amp.
Jan 03, 2013 | Rockford Fosgate T1d212 12" Power T1 2-ohm...
I have 2 dvc 4 ohm alpine type r 15's and 2 svc american bass
Hi mate very nice amp you got there here is the specs for it
Model: MA Audio HK401SX
Hard Kore Series 1800 Watt 1 Channel High Performance Class X Car Amplifier
1 x 1800W RMS @ 0.5 Ohm Mono
1 x 1200W RMS @ 1 Ohm Mono
1 x 650W RMS @ 2 Ohm Mono
1 x 500W RMS @ 4 Ohm Mono
Fully Unregulated MOSFET Power Supply
2 Ohm Stable @ Mono
1 Ohm Stable @ Mono
0.5 Ohm Stable @ Mono
if you have 2 12s just bridge them and you will have 650wrms at 2ohm running to them or one sub at 4 ohm 500w rms ps they should pump iam running 2 12s with just 360rms at 2ohm and they do the job good luck
Oct 19, 2009 | MA Audio HK401SX Car Audio Amplifier
How do i bridge 2-4ohm dvc's to a mono block
If you have a DVC 4ohm speaker, and you are using both voice coils, the amp is seeing a 2ohm load.
If you bridge the amp, you CAN run both subs as long as the amp is Two Ohms Stable.
Wire each subs voice coils in parallel.(Positive to positve, neg to neg.) (2ohms) each.
Then wire the two subs in series.(Neg from amp to neg of sub one, pos of sub one to neg of sub two. then pos of sub two to pos of amp.
If it sounds too hard, leave it as you are already running the amp at two ohms.
Sep 13, 2009 | Car Audio & Video
How do i wire a qvc subwoofer to a 3000w 1ohm stable monoblock amp
depends on the amplifier if you have a mono block amp or a regular 2 output amp if it is 2 output make sure to bridge and that means the negative to one output and positive to the other output then need to find out the rms on the speaker. the amp should have the ability to adjust it you might want to get a digital multimeter set it to watts and make sure you only set it to the RMS of the speaker because max handling should be the 1800 and usually the RMS is half the max so it should be 900 w again it depends on the amp and were the adjusting knob is and or if it has one
Nov 04, 2008 | Car Audio & Video
Wiring Diagram
i HAVE 2 12 KICKERS L7 RUNNING ON A PERFORMANCE TECHNIQUE AMP 2000 WATS THE ampl its a mono //and i want to know how to wire the speakers
Jul 26, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Targa Card.....Please Help!
If your PC tells you the driver is not found, the card itself is working but the problem is in the software.
Chances are that a microsoft update caused this problem, specially if you pc is set to automaticly update windows.
Try re-installing the targa drivers, this might help.
Otherwise try to find out if there is a driver-update available on the relevant website of Targa.
Jun 30, 2008 | Targa Computers & Internet
Targa Top
Targa's are heavier than the solid roof supra cause the body panels are reinforced , cutting the roof to make a targa gonna weaken the structure greatly , if u gonna do it then theres a lot more to consider that just your saw blade, I got a 86.5 an with the roof off there's still body flex so be careful bro
Jun 29, 2008 | 1987 Toyota Supra
Head unit
If the display goes out then it is possible the flex cable is broken. Return it to Rockford for repairs.
Jun 19, 2007 | Rockford Fosgate RAV DVD1 Car DVD Player
Car Audio & Video Logo
97 people viewed this question
Top Ohm Car Audio & Video Experts
Harrie
Steve Pack
Steve Pack
brian williams
Are you an Ohm Car Audio and Video Expert? Answer questions, earn points and help others
