Question about Compaq Presario 5000 PC Desktop
Switc on fans run. No beeps. Screen blank
Switch on fans run, power light comes on, dvd light flashes. No beeps. Screen blank.
Posted by sean_dodds on
Anonymous
    Problem Solver:
  • 30 Answers
Just reinsert your RAM; it will work.
Posted on Oct 20, 2009
Blank screen
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Cdc-m computer will not come on the on light works case fans comes on but that is all
Do you mean that your computer does not turn on just casing light lit on and Fan runs only? What means new, memory and case?
If just lights on, fan runs but no image on monitor or blank screen, you should hear some kind of sound form inside of the CPU casing. This is called beep code. If you hear continuous beep or 3 same beep with same length, it means your motherboard is missing RAM, just connect it properly. If does not work or stop try a good RAM installing to see the result and plug your this RAM to a working machine that have the same kind of RAM.
If you hear one long beep with two short beep After PC switching on, or Two long beep with one short beep following - that means your Graphics card is not connected properly, or damaged or miss matching. If you do not have any beep code after switching on the machine, your motherboard may not have build in emergency speaker. Try to clear this things first. Please mention details of your computer with model number of your motherboard. Let me know updates.
Blank screen
Did it boot all the way? Do you hear the fan running, disk drive spinning? If it sounds like it booted but the display is black, try this:
When you press the power button do you hear fansrunning, hard drive spinning, lights on the computer, hear any beeps or lightsconstantly blinking, hear the DvD/CD drive click and the light on the drawer ofthe DvD/CD turn on for a second or two? If so the laptop is trying toboot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
I have a fujitsu e8410 which will not start up properly, when i push the start button it shows power but then the fan comes on and the cap num and shift lock leds flash and nothing else. can you help?
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Hi I have HP540 notebook. last night I tried to shutdown it, but it was not turning off and now i am unable to switch it ON. there is just black screen, no clue what to do. please help me ASAP.
First thing to try is remove the battery, RAM, HDD, CDD. Then reinstall them and try again.
Does any light come on, such as power, battery, etc? Any beep sound? If no lights, then you have a power issue, either your A/C adapter or DC jack on the motherboard is loose (try wiggling).
If has light and hear the fan spinning, but no beep at all with blank screen the whole time, then more likely your motherboard is fried. Take it to your local computer store.
Just in case, take a flash light and flash it to the LCD, do you see any image? (will be very dim) If you some image, then either your LCD inverter or lamp is out. Take it to your local computer repair center.
5helpful
Power light comes on, but will not boot, also fan doesen't come o
Without looking at it sounds like a dead motherboard. You should be able to take it to a local shop and have then check it out for about $35-$50
2answers
Compaq presario CQ50 106CA. When powered on the power light and wireless light illuminates. The DVD sounds like it's initialising and fan runs, but screen blank. Ihave tried all basic fault finding...
Have you tried turning it on and selecting the function key combination for the screen? For example some screens use FN+F7, hold down the Function key and F7 to cycle between presentation modes.
Had trouble booting the computer over time. Sometimes power light would come on and nothing else. By unplugging, waiting 15sec it would power up. Over time this stopped working. Eventually power light...
Time to look for a new computer. That and take out your hard drive to copy your files over.
Sounds like motherboard problem. Probably not worth repair.
I've got an HP desktop with similar problems. It turned on one day just fine. The next day not. I don't even get the boot up screens. Disconnecting Hard Drive and CD/DVD components do not help. I should at least get some BIOS POST beeps and a Hard Drive Not Found or such. I do not. On occassion it will boot to a blank screen with white cursor in upper left. Most the time no screen at all. On rare occassion it comes right on and boots Windows. I guess it could be the power switch ... but I doubt that.
Compaq Presario 5000 PC Desktop Logo
Top Compaq Computers & Internet Experts
Ekse
Abhinandan  Patil
Abhinandan Patil
Michael Thomas
Michael Thomas
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
